Is this a symptom of possible bad caps?
  • X509Certificate
    • Jul 2008
    I've been having some very strange problems with a Tyan S5396 motherboard. When I hit the power button the CPU fans, case fans, and GPU fan spin but the board does not POST. Instead, it just sits there with the fans spinning. Sometimes if I power it off from that state by holding down the power button for a while then hit the power button again it will startup and POST. After a successful POST everything is fine. This is my third Tyan board with this kind of problem.
    I have:
    1. Run with only one stick of RAM. Swapped the RAM. No RAM (Get the right beep code)
    2. Run with only one processor. Swapped processors.
    3. Used a different video card. No video card (Get the right beep code)
    4. Tested power supply voltages using power supply tester.
    5. Swapped power supply for one with more power (went from 850w Thermaltake to 1000w Silverstone)
    6. Removed all connection to case headers and drives.
    7. Removed board from case and run it on top of non conducting surface.
    8. Tried to turn on the board by shorting the right pins instead of using the case button.
    Nothing helps. No matter what I do I always have to power it on, wait for a bit while the fans spin, shut it down, then press the power button again. Sometimes even that doesn't work and I have to play with combinations of hitting the reset button and power button and pray that it starts up (usually does start eventually).
    Could this be a symptom of bad capacitors? I visually inspected them following the instructions on the badcap website but could not find anything wrong with them. Besides visually inspecting the capacitors how can I verify that they are OK? Any other theories about what could cause this problem?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Is this a symptom of possible bad caps?
    post pics of the board and caps.
    i just recapped a bunch of tyan stuff that were full of brown noname caps.
    they would not post or if they did they would lock up.recapping fixed every one of these.
    • X509Certificate
      • Jul 2008
      Here are some pictures. Sorry they're not so great but I didn't have time to take the motherboard out of the case and take better ones. Some of the caps say Rubycon and others say Sanyo
      Let me know if you need better pictures.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        am i seeing things or are a few of those rubycons starting to bulge?
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          I was seeing that myself, but the pics weren't clear enough. Also, please try resizing them, they took ages to download!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • X509Certificate
            • Jul 2008
            Sorry about the pics guys I took them at the last minute before hopping on a plane didn't have time to take the motherboard out of the case. I'll try to get better pics when I come back. My impression from observing them in person is that they might be slightly bulging but I'm no expert and don't know what's normal and what is not. Certainly they're not blulging as bad as some of the pictures on this forum.
            • Fizzycapola
              • Oct 2006
              • 423
              affordable 10 - 14MP camera's this xmas
              Rubycon Rubycon Rubycon
              • linuxguru
                • Apr 2005
                • 1564
                Are those white-striped MCZs genuine stuff? I thought they were gold-striped. Maybe the Indonesian Rubycons are always white-on-black...
                • Yamo
                  • Nov 2008
                  I just wanted to toss my hat into the ring here because I'm experiencing the exact same problem (though on a different motherboard, Gigabyte P35-DS3R) and would love to see a solution. When I first push the button, I can hear the fans begin to hum, but then it stops here and doesn't continue to boot - nothing lights up on my keyboard and the monitor sits at "please check signal cable". Then I have to wait maybe 15 seconds or so (if I don't wait it has a tendency to repeat the previous step), power down, and then power on again. This time around, everything is normal - the fans hum, my NUM/CAP/SCR lights blink for a second, and the computer does its regular POST business
                  After posting my problem on another board, I was pointed here because my situation looked like it might be caused by bad capacitors, so it's sort of comforting to know that someone else is going through exactly the same crap that I am
                  • emil_t
                    RTX3090 working fine but fans not spinning
                    by emil_t
                    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                    04-12-2024, 06:54 AM
                    ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                    This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 10:50 PM
                    ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                    This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    09-06-2024, 11:05 AM
                    ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                    This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                    This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
