Hiya,
I am new here at the forums, and that may be why I couldnt find answers to these quick questions...
I am working on a failed system... No nothin' on power up attempt... (P.S. green light flashes when I connect it to mobo...) 2 bulged caps (1000microF) next to cpu... Larger caps in same row, and others on the mobo, are 'unbulged'...
Is it likely that replacing those two caps will enable the mobo to function?...
How likely is it that failure of the mobo caused damage to the cpu?
How likely is it that a new cpu would be damaged by a 'repaired' mobo?
Answers, or pointing me toward them, will be much appreciated...
One more quick one... Did I see somewhere here in the forums a warning against 'Bestec' P.S.'s?
regards... dnorm
regards... dnorm
