How can I identify bad cap with a help of oscilloscope?
BAD caps and Oscilloscope?
Re: BAD caps and Oscilloscope?
Do you want to measure in circuit or out? It is difficult with a scope to get a good measure. If in circuit and operating you will see an increased ripple current if bad, but this needs to be compared with the normally expected ripple value.
Externally would require a powerful signal source that would depend on the type of cap and frequency of ripple in circuit.
Best method is ESR meter.Gigabyte EP45-DS3L Ultra Reliable (Power saver)
160Gb WD SATAII Server grade
Nvidia 8500GT 256Mb
Samsung 18x DVD writer
33 way card reader
Windows XP Pro SP3
17" Benq FP737s LCD monitor
HP Officejet Pro K5300 with refillable tanks -
Sure, I have one ATLAS ESR meter - i'm still playing with it and learning. Maybe I'm confused...but how do you isolate faulty smt ceramic capacitor in circuit? It's not practical to desolder it...I was thinking maybe I could measure rippleOriginally posted by davmax
on the scope, and decide if the particular smt ceramic capacitor is bad/ok.
Thanks.Comment
I think you will find an ESR meter somewhat useless for them.smt ceramic capacitor in circuit
an in circuit capacitance type meter may be of more use.
(these usually work by using a low Level AC frequency to calculate the capacitance, this enable them to not switch on semiconductor junctions...there are possibly with
in-circuit "let the buyer beware" situations thought)
(the above function outline is if memory serves me)
If you really in doubt best idea is replacement
I suppose it depends on what its designed to do in the circuit and the circuit and signals
if you trying to sus it out with a scope.
As davmax has said it usually a matter of knowing what should be there and comparing it with what "is there"
there is I believe, a fault that tends to happen with them (depending)
and thats physical, as in the ends break due to stress but mostly they should survive well.
(unless abused it some way)
Davmax would probably be one of the better people around here to advise on possible issues. (there are others of course)
Hope this helps anyway
Cheers
You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
That is a very difficult situation. Ceramics are usually OK. You cannot test with ESR meter or scope. Usually if suspect replace it (low cost item). However it may not be too easy to source a replacement.Originally posted by ddsSure, I have one ATLAS ESR meter - i'm still playing with it and learning. Maybe I'm confused...but how do you isolate faulty smt ceramic capacitor in circuit? It's not practical to desolder it...I was thinking maybe I could measure ripple
Thanks.Gigabyte EP45-DS3L Ultra Reliable (Power saver)
Nvidia 8500GT 256Mb
33 way card reader
Windows XP Pro SP3
HP Officejet Pro K5300 with refillable tanksComment
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by quicknameI'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
I decided to verify that the batteries were... -
by Paxman_SwedeHello!
I have studied the board and...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
by CdDvdFlashI have a LG RC689D power supply to replace caps but I'm not sure about ripple current values, one cap is 16V 2200uf 105c and I found the two below caps that I'm thinking of getting but do I choose one with a low or high ripple current?
https://au.rs-online.com/web/p/alumi...citors/0374433
and
https://au.rs-online.com/web/p/alumi...citors/7037501-
- Loading...
