You are subscribed to this thread Asrock G31M-GS is using OST & KZG caps
  • liukuohao
    • Oct 2013
    • 63
    • Malaysia
    I am just curious to find out whether anyone in the forum
    has this motherboard?
    So, far in my experience, I have not seen a leaking OST caps.
    So, I need to know whether it is worthwhile of replacing them
    in terms of long usage in a hot environment.
    Asrock G31M-GS is using the following electrolytic capacitors:
    1 piece of OST 16v 470uf-----> Not sure want to replace it or not, although it is listed as bad caps?
    10 pieces of OST 6.3v 1000uf -----> Not sure want to replace it or not, although it is listed as bad caps?
    4 pieces of KZG 16v 1000uf-----> planning to remove it and replace with Rubycon ZLH series from RS components.
    Any advice?
    Thank you.
  • liukuohao
    • Oct 2013
    • 63
    • Malaysia
    Re: You are subscribed to this thread Asrock G31M-GS is using OST & KZG caps
    I just posted some pictures, and see is there anyone can
    advice me whether I need to replace those OST caps.
    The KZG 16v 1000uf Chemicon caps will be replaced with the Rubycon 16v ZLH series 1000uf
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • BigTroll
      Asrock DeskMeet return of the bad caps
      by BigTroll
      I have had good luck with asrock products but with that said I ordered a DeskMeet X300 to use up some other components I had laying around Ryzen 3600 GTX 1060. it comes with a 500w power supply built by CWT.
      I thought CWT would use good components but no the primary cap was ChengX and the secondary had lots of chengx and JunFu caps. hope it lasts awhile. I do have a 450w SFX silverstone with teapos on the secondary I could replace it with.
      10-14-2023, 11:57 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
