Rubycon MBZ leaks in storage!
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    #41
    Re: Rubycon MBZ leaks in storage!
    Originally posted by mockingbird
    Are you saying that overvolting caps with very low current will not harm the cap?
    Well, I am not saying that overvolting caps is safe. But you can apply the maximum rated voltage on the cap without consequences, if you have a resistor in series with the cap to limit the current. Generally, that should be a few to a few hundred uA (microAmps), which for most electrolytic caps we use here, is close to their cap leakage current. With a 10 KOhm series resistor and 5V as the power supply, the maximum current that can flow through the cap will be 5V / 10 KOhm, or 0.5 mA (500 uA).
    Also, electrolytic caps can usually withstand a "surge" voltage that is slightly higher than their rated voltage. For example, if you look in the United Chemicon KY datasheet, you will see that 6.3V caps can take up to 8V surge for short periods of time without damaging the caps.
    In that case, there's no reason to reform the cap at a lower voltage, just at a low current, correct?
    Not exactly.
    Technically speaking, you may be able to get away with that, because once you go over the rated voltage on a cap, its internal leakage current greatly increases. And if you are limiting the current, the voltage across the cap will drop due to the increased leakage current. Of course, you'd have to be very careful about limiting the current. If you don't limit it enough, you can internally overheat the cap from the overvoltage and damage it.
    So maybe I should set up some sort of decade resistance array hooked up to some kind of switching system on my jig.
    Here is how I do it:
    V1 is the power source - in my case a 20V laptop adapter for 16V and 20V caps and 9V wall-wart that outputs 14V unloaded for 10V and 6.3V caps.
    The way I work it:
    1. Remove the 10 KOhm series resistor (R1)
    2. Adjust 1 KOhm pot (R2) to appropriate cap voltage (i.e. about 6V for 6.3V caps and 9.5V for 10V caps)
    3. Re-insert back 10 KOhm resistor and leave the setup alone for some time
    C1-C3 are the caps I wish to reform. You can have as many as you like in parallel (but less than 10 is a bit better to avoid large charging periods, especially when you go above 1000 uF caps). I usually build the setup on a breadboard and insert/remove parts and caps as needed.
    I don't think I have any 12V adapters that can do more than 1A. But with a PC PSU, I can go all the way to the maximum of the 12V rail, or at least up to the 2A - 5A of current some of these caps handle.
    With a 10 KOhm series resistor, you won't need anywhere near these currents. A few mA would be more than enough. So anything from a wall wart to a few 9V batteries in series will do the trick here.
    • mockingbird
      • Dec 2008
      • 5488
      #42
      Ok I was thinking that actively passing large amounts of current through the cap would be part of the reforming process. But that's too complicated for me to set up, and the way you are doing it is more than adequate.
      Thank you very much for all the help.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        I've seen all the major brands occasionally do this. A lot depends on how it was stored.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • bjs59
          Infamous Rubycon MFZ... Current recommended replacements???
          by bjs59
          What we have here today is an Intel DG33FB motherboard, circa 2007... I need to replace some of the caps on this board... From what I have found, one of these caps was sort of well known here back in the day as they were used in XBoxes and XBox 360s as well....They are the Rubycon MFZ series, in particular the 6.3 v 3300uf 10mm X 20mm... I have found a seller on Amazon, The Capacitor Store, that has them listed but I have a hard time believing these are genuine pieces... The original recommendation was to replace any bad ones with Nichicon HZ series since the Rubycon MFZ's were a custom product,...
          12-10-2020, 10:47 AM
        • triplefour
          JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
          by triplefour
          got this tv from a friend who got a new one and didnt want to bother repairing this one.
          he said it sometimes would just flash color patterns.
          and sometimes it would just work
          i figured it had some intermittent mainboard issue.
          i stored it at home for a while before looking at it
          when i plugged it in for the first time, i heard some popping noises
          and then a big cloud of white smoke came out of the back of the tv!
          i noticed the smoke didnt actually smell like anything. not like when an IC blows.
          i unplugged it and took the back off and discovered...
          12-18-2022, 12:38 AM
        • SwedishDiesel
          Panasonic caps - dried electrolyte on leads/bung from factory?
          by SwedishDiesel
          I just bought these from Mouser and upon closer inspection the area where the bung and leads meet has some dried green substance on it, presumably dried electrolyte. Is this normal?...
          03-03-2022, 06:06 PM
        • DXseekerMO
          Failed UCC and Rubycon replacement on a Dell XPS410, equivalent?
          by DXseekerMO
          Hello, I'm working on an old Dell XPS410 with burst capacitors. I'm trying to source either an equivalent replacement, or a replacement that will work. It's been suggested to me to use Poly caps as a replacement, but I have no idea what to order or what will work.
          If anyone has a link to where I can buy what I need that would be even better.
          These are the caps that have burst:
          Board location: C8BV, C26BV, C43BV
          Brand: United Chemi Con
          Series: KZG
          Size: 10mm dia X 25mm height
          Impedance: (ohms max/20c, 100kHz) .012
          Ripple: 2800...
          02-04-2022, 04:48 PM
        • SwedishDiesel
          Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
          by SwedishDiesel
          Howdy folks,
          I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
          10-30-2021, 12:47 AM
