surface mount 10uF capacitors?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    I was trying to figure out why my 20-year old car's transmission won't shift unless it's warm outside (seemingly). It has an electronically controlled tranny. However there was just one 470uF 35V radial capacitor on the board. I swapped it despite it seeming to be ok, but that didn't fix it.
    Oh well.
    However there are still three 10uF surface mount caps (rectangular, polarized)... I wonder if they could also go bad.
    Not sure what else could be temperature dependent, capacitors definitely fit the bill. Rest of the stuff on the board are resistors, ICs, multilayer ceramic smt capacitors, a relay, voltage regulator IC (series dissipative on heatsink, and seems to be outputting 5V just fine), power MOSFET (on another heatsink), ...
    • 31289
    Re: surface mount 10uF capacitors?
    check for cracked solder joints - specially on parts that are fixed to something else like a heatsink or case section.
    • redwire
      • 3912
      I would re-solder the connector and any big parts, Vibration is hard on the boards. But it could be the mechanical (solenoids) or temp sensor.
      How old is the tranny fluid?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8711
        The "large" still look well soldered. Fortunately it's only a double sided board, but unfortunately all of the ICs and semiconductors have custom part numbers on them, so I have to guess what the original part is.
        It definitely is some sort of temperature relation which is very weird. One experiment that I did, after the warm up period that the tranny start working again, I opened the windows and cooled down the cabin as much as possible...and then upon next start, it stopped working properly. I let the cabin warm up once again and it started working again.
        But I pointed a hair dryer at the TCU... it didn't start working properly...
        Very weird. I can't rule out tranny problems vs electronic problems but the fluid's fairly fresh.
          • 31289
          foto's of the board?
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8711
            Looks like a lot of OEM renamed parts. The two heatsinked items look intact but I should go ahead and reflow them anyway...
              • 31289
              try resoldering the 2 parts with heatsinks and the crystal and relay.
              when i say resolder i mean remove the old stuff first, not just slap more ontop.
              • clearchris
                • Dec 2013
                • 687
                If you swapped the electrolytic already, my next suspect would be the relay. I have had a fair number of those go bad... They can also go flaky, working sometimes, sticking on, sticking off, etc.
                Haven't really had a problem with any tantalum caps (the orange caps).
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                  Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                  This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                  09-06-2024, 08:10 PM
                  Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                  This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
