Who makes these caps?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Red with "CV" printed on it:
    http://www.newegg.com/Product/Produc...27&ignorebbr=1
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • mockingbird
    • Dec 2008
    • 5488
    Re: Who makes these caps?
    I used to know, because I bought some old stock once to check the quality. I suspected they were Samxon prototypes, but they're not. They're actually pretty poor quality, internally at least, compared to japanese polymers.
    If you open these up, the polymer is cakey and inconsistent, unlike a Japanese polymer that is neat and uniform. I used them on a passive ATI X1300 card, and they work fine, but don't count on them.
    Not all polymers are created equal. Japanese ones really are worth the extra money.
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
      by momaka
      03-12-2025, 03:42 PM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
