Need help identifying these caps!
  • theOracle
    • Nov 2012
    • 163
    what amount of capacitance are these and what brand and what type?
    and are they a type that has been known to fail?
    they are about ~12 years old.
    I am assuming the 4 in the top pic are 100 uF and 35V
    and the one on bottom appears to be 47 uF and 50V
    so I guess my main question is what brand and type are these and are they low ESR and especially, are they known to fail much? - I do not see any visual signs of failure, but I am suspecting them.
    __________________
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: Need help identifying these caps!
    Those are most likely Nichicon UX.
    Datasheet.
    They are general purpose SMD electrolytic capacitors from Nichicon rated for 2,000 hours at 105*C (excepting the 160V ones and higher which are rated for 3,000 hours) in terms of load life and 1,000 hours at 105*C on the shelf. The datasheet seems to specify the same "2P" markings present on those capacitors in the image. Couldn't know if they are the issue without measuring them. However, I believe Nichicon WX (2,000 hours @ 85*C 5.5mm tall GP SMD lytics from Nichicon) have been known to leak from the bottom with old age, but I haven't seen any leak on Intel motherboards within the last 10-13 years, probably because they're not in stressful locations. The "A3" and "B4" markings on the SMD capacitors in your images likely mean that they were produced during the 3rd week of January, 2003 and the 4th week of February, 2003, in accordance to Table 12 of JIS C 5101.
    • theOracle
      • Nov 2012
      • 163
      I have a stock of very high quality low-ESR, 105C, through-hole caps from the manufacturers at the bottom of my signature and considering replacing these with them!
      by the way, your date decoding jives!
      everything else on this board is super high reliability, that is why I suspect the caps
      "it's always the caps" as the saying goes (lot of truth in that saying)
      __________________
      the BIG 4
      • theOracle
        • Nov 2012
        • 163
        Here is what I am unclear on, I can see now that these are definitely Nichicon, and I see the high temperature marking, but how do you know they are the UX series, it seems like there are about 20 different Nichicon chip-type SMD electrolytic series - how do you identify the series? - like why couldn't these be UD series, for example?
        __________________
        the BIG 4
          • 31151
          i dont tink it's Nichicon, that leaning over "o" symbol looks familiar.
          it may be korean - pos samsung.
          • Wester547
            • Nov 2011
            • 1268
            • USA.
            That "O" symbol is on Nichicon SMD lytics, affirmed in the datasheet.
            Because Nichicon UD capacitors have "UD" marked on them.
            UD datasheet. Those are most likely UX judging by the voltage ratings on those capacitors. They could be WF but WF doesn't go up to 50V.
            • theOracle
              • Nov 2012
              • 163
              leaning over "o" symbol is definitely Nichicon, look at the datasheet linked to in post#2
              __________________
              the BIG 4
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
                by momaka
                03-12-2025, 03:42 PM
              • crosswinds
                Assistance with identifying replacement caps on ASUS P5VDZ-MX
                by crosswinds
                So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
                Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
                Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
                Its a ASUS P5VDZ-MX board.
                I would really appreciate some assistance on what the best replacement caps would be for these:
                Panasonic(M)...
                04-17-2024, 04:25 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • fl0w
                GeForce 6800GT recap, need help identifying caps and finding replacements
                by fl0w
                I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
                But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
                I need to replace:
                • 2x 2.5V 1500µF => I plan to use this
                • 2x 16V 330µF=> I plan to use this
                • 1x 6.3V 680µF=> I plan to use this
                Am I correct with the cap choices?
                Thanks for...
                10-02-2024, 11:28 AM
