Samsung Plasma Blowing Fuses
  • nautical naturist
    • Sep 2014
    • 8
    This PN59D530 runs in a restaurant 10-12 hrs a day. after about two years it blew the 10amp/250v power input fuse. I could not find a replacement ceramic fuse so I used a glass slo-blo 10a/250, which blew immediately. The power runs through a choke then the rest of the circuit. It has four transformers, including a large PB6F-VS. I have already bragged to my boss I could fix this TV, expecting bad caps. Now I am stuck. Help!?!?
    Keith
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Samsung Plasma Blowing Fuses
    pics?
    Follow the white rabbit.
    • nautical naturist
      • Sep 2014
      • 8
      Pictures are difficult for me, but I will try. I have not seen any popped caps or dark spots under diodes or resisters. I cannot check anything because the fuse blows as soon as I apply power. I will try to get some pics.
      • nautical naturist
        • Sep 2014
        • 8
        Still cannot get pictures from my telephone. Working on it.
        • nautical naturist
          • Sep 2014
          • 8
          I give up!! I cannot get you pictures of the PSU. It looks OK, no apparent damage. Could you tell me where to find a tech/repair manual? I tried "Tom's Manuals" but could not get past the language converter download.
          • nautical naturist
            • Sep 2014
            • 8
            Any one?? Please..
            • bazzbarro
              • Dec 2012
              • 25
              • kenya
              Nat whenever u see a blown fuse do not replace it before finding out the couse of it to open just test all the components stage by stage or one by one also use a bulb connected in series in the place of a:popcorn fuse
                09-07-2024, 05:50 AM
                How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                by sam_sam_sam
                About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
              • Sik_6ty_Sixx
                HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                by Sik_6ty_Sixx
                So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                02-18-2025, 05:06 AM
                Surface Mount Fuses Fundamentals Datasheet
                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                10-07-2024, 06:07 AM
                09-06-2024, 11:40 PM
