Stances against fake brand name capacitors
  • japlytic
    • Oct 2005
    • 2086
    http://www.rubycon.co.jp/en/news/20131203.html
    https://gcnet-public.sharepoint.com/...%E3%83%A0.aspx
    Do you know of any other manufacturers of capacitors making a stance against fakes?
    If you find them, please provide links to them as well.
  • CapSwapper
    • Feb 2014
    • 69
    Re: Stances against fake brand name capacitors
    the problem is it's a cat and mouse game that goes into infinity. you are dealing with communist countries with no respect for international law. for every manufacturer that's exposed they just close down and open up somewhere else under another name.
    • CapSwapper
      • Feb 2014
      • 69
      Rubycon is great if you can get real ones. so many fakes being made
      • c_hegge
        • Sep 2009
        • 5219
        http://www.nichicon.co.jp/english/products/
        If you scroll down a bit, there is an alert about fake parts on Nichicon's product page too.
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          And NCC.
          http://www.chemi-con.co.jp/e/counterfeit.html
          • sparkyrick
            • Nov 2014
            • 12
            So how can you tell if you're getting the real mccoy?
            • Agent24
              I see dead caps
              • Oct 2007
              • 4963
              • New Zealand
              Best way is to buy from a big, well known electronic components\parts distributor or reseller like Badcaps, Digikey, Mouser, Farnell\element14\Newark, RS Components\Allied Electronics etc...
              Do NOT buy from eBay, Amazon, DealExtreme, Aliexpress etc...
              If you already have some capacitors you are suspicious of, check them against photos of genuine ones or post the photos here.
              -David VanHorn
              • Olkus
                Elna capacitors - fake?
                by Olkus
                I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
                09-01-2023, 02:45 AM
              • dragon3x
                by dragon3x
                power on.
                Here are some examples :
                switching supply area).
                than 6.3 V.)
                03-21-2025, 02:46 PM
              • Stanley1843
                BEST 505 Vs Mechanic Brand Reballing Balls with Lead
                by Stanley1843
                has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
                06-22-2024, 11:06 AM
              • slybunda
                AA and AAA battery charger capacitors?
                by slybunda
                hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                it has inside:
                2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                2 x 470uf 16v LZ105c branded as G.Luxon
                not heard of these brands are they any good?
                iv attached photos of the charger and the board inside for an idea on the type of...
                12-24-2023, 04:41 AM
              • Hitto
                Fake Nichicon capacitors with almost-perfect sleeve?
                by Hitto
                Fake Nichicon capacitors with an almost-perfect sleeve?
                Same font, perfect logo, same size of the sleeve. The air vent looks okay. The diameter of the capacitors is correct per datasheet.
                It truly looks like the real thing.
                I doubt that you would distinguish it from a genuine one.. if it wasn't for the bung.
                Shall we be afraid, at this point, that even the bung can be replicated?...
                01-09-2021, 03:07 PM
