Capacitor Replacement Verification
  • airlinetech
    • Dec 2025
    • 5
    I've been reading this forum and think I've picked out some replacement capacitors, but wanted to double check with somebody else to verify my sanity 😆.
    Current Capacitors - OST RLX
    Going off of this PDF: https://www.badcaps.net/download/?id=86ad7b31
    16 Volts
    1500 uF
    10x25 mm
    .020 ohms
    2780 mArms
    10 Volts
    1500 uF
    10x16 mm
    .022 ohms
    1800 mArms
    Planned Replacements
    16 V
    1800 uF
    10x25 mm
    17 mOhms
    2.9 Amps
    10 V
    1500 uF
    10x25 mm
    22 mOhms
    2.15 Amps
    Any help is appreciated. Thanks!
  • andrewsawesomr
    • Jun 2022
    • 114
    • United States of America
    • Coding, Electronics, Music
    Can you provide the brand and series of the planned replacements?
    • airlinetech
      • Dec 2025
      • 5
      Hi Andrew,
      The 16 volt ones are Nichicon UHW and the 10 volt ones are Chemi-Con KZE looking at the datasheets. Thanks for your help!
      • andrewsawesomr
        • Jun 2022
        • 114
        The series look good. For the 16 volt ones, just make sure the application isn't capacitance-sensitive, otherwise you might be better off getting the 1500uF UHWs.
        • airlinetech
          • Dec 2025
          • 5
          Thanks. I probably should get the (or some) 1500 uF ones . Someone else said I should. I was reading about ripple values a little bit here, but I haven't been successful finding 16V 1500uF capacitors with a ripple value of 2780 mArms....
            • 31927
            those will work,
            you dont need to be that well matched though.
            • airlinetech
              • Dec 2025
              • 5
              Thanks! talking with someone else, I may just get ones that match the capacitance more closely than the ripple. I was thinking these: https://www.mouser.com/ProductDetail/647-UHW1C152MPD, at least or the 16 Volt ones.
