I have acquired a dead Samsung 266CM monitor and found a YouTube video that describes how bad caps cause the problem and that they can be replaced. So last night I found a company on eBay that has a pre-made kit of about 8 capacitors that are specifically for this model monitor, for about $10.00, so I ordered one. It should arrive on Monday, about 3 days from now.
However, I have other pieces of hardware that may also be bad due to bad caps and so I would like to learn more than just what I need to repair this Samsung monitor.
During the YouTube video, the guy mentions that he purchased caps that were "approved for power supply use" or something similar, and that he purchased them from Mouser.com, but when I went there, the search parameters were very crude.
So with all that as "background", my question is how many different ways are there to specify capacitors? I'm aware of farads (capacitance) and voltage rating, and I see the spec "radial" although I'm not real certain what that means, but where did this idea that some capacitors are better suited for power supplies come from? Also, given the extremely wide variety of manufacturers, how does someone make a decision on what brand to purchase. Is there a short list of the "best" manufacturers?
What I'm doing is getting ready to open up some of this other hardware and buy caps to repair it, that may not have pre-made kits available. For example, if I pull a blown 820 uf cap that's rated at 25 volts, of all the hundreds of choices, what cap do I purchase from (for example) mouser.com? Are there pitfalls to avoid? Special purpose caps that are never suitable for anything other than something very specific? Are there high quality caps that are always better than everything else, that might cost more but have off-setting positives that make the additional cost worthwhile?
Thanks in advance for any help.
