Caps and ESR
  • Larrob19
    • Mar 2025
    • 30
    Caps and ESR
    I would like some advice on ESR. I have 3 Capacitors that are 68uf 500v. The 3 are showing about 62uf and 0.66 ohm. Does the ESR look OK?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8146
    They seem to be within tolerance. However high voltage capacitors have higher ESR from the get go than low voltage caps and actually need to be checked with a big ESR meter that ca do a leakage test. These little ESR testers do not charge the capacitors up to 500v. Just food for thought. This cap may be ok for the TV”s, but for big things that need a lot of power, leakage test it is hands down.
    • Larrob19
      • Mar 2025
      • 30
      Thanks for the info CapLeaker. The reason I asked was because it's a Samsung TV Power Board and it keeps burning 2 Power Mosfets and the main fuse. It never blows the Blue Caps next to the Mosfets or the Diode also. I connected a 100 watt light bulb to it and when plugged it flashes 1 to 2 times per second. I have looked for a schematic for this board BN44-00874C but no such luck. This has me stumped.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8146
        Look at the gate drive including the PWM for start. Maybe make a new thread in the TV section about your problem TV, take some straight shot, high resolution picture pics and upload via attachment function and explain exactly what had happened and what you did. There are some real capable folks here on badcaps.
        • Larrob19
          • Mar 2025
          • 30
          I will try that. Thanks CapLeaker.
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
