Strange capacitor types in old oscilloscope
  • ank
    • Apr 2014
    • 8
    • Cyprus
    I have been trying to repair an old Telequipment D32 oscilloscope and came across this video https://www.youtube.com/watch?v=BOeEbyIllcM.
    Can somebody identify what the type of capacitor is shown at around 13:31 of the video? What would be a good replacement, if needed? Mostly out of curiosity, actually. thanx.
  • mariushm
    • May 2011
    • 3799
    Re: Strange capacitor types in old oscilloscope
    They're either tantalum or mica/film capacitors. 100 is probably 100nF or 0.1uF but double check by measuring other capacitor with same value or look in the service manual which is probably this one:
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      I'm going to guess it's a polystyrene dielectric capacitor, which was (not easy to find anymore) very stable over temperature. If you have to replace one and can't find a polystyrene part, I would suggest mica or polypropylene dielectric parts, in that order of preference.
      PeteS in CA
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
