Hey Guys i got some Problem on this PC SF ( Compaq D500 SFF ) the small factor. the problem is sometime it can boot but sometime it can't and even sometime it has RAM slotted (beeping) , and sometimes Failed to Run Memory test . What is the problem is it the Caps or anything other electronic part problem , but i saw a TAEPO or TEAPO capacitor ... is it a problem ??? What I heard this kind of caps had a problem... please help me
Compaq Motherboard problem...
Re: Compaq Motherboard problem...
Hmmm, what I'd do first is check the power supply. A failing power supply can mimic the effects of bad capacitors on a motherboard; sometimes, power supplies fail because of bad-quality capacitors that blew inside them!
And yes, TEAPO aren't exactly the best of caps to use in motherboards, but they're far and away from being the worst. I'd try to eliminate the power supply as a potential problem first.Last edited by UraBahn; 07-01-2007, 11:40 AM.The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.) -
knowing HPs the power supply should be the first to replace, as it is a Bestec. actually, you better replace that before it burns down the whole motherboard. the sad thing is that even their business (HP Compaq) computers have started to use Bestecs. That's also a SFF, so it might be hard to find a replacement for.Comment
Well it could be. You should open up the power supply and have a look....post a picture here. The ticking noise could be an inductor ringing, a capacitor ringing and just a very bad fan. In any case, opening it up and inspecting it will not hurt. Just make sure you inspect it when it is turned off!Comment
GuyS,.. Here the PiC of the D500SF power Supply..... im thinking the sound tiking is the 2pin Relay (blue colour one) got two there .... and the bad news is the mobo not posting (of course changed Caps already) still not posting and no beeping ..... and some tiking sounds from PSU ....i suspect the PSU ...how bout ur guys ?? here some of the pic of the PSUComment
well no idea really on that psu
but they look like mains rated capacitors to me (x or y can never remember position)
The ticking sound sounds to me like the psu is trying to start but can't fire up due to a fault
what the exact faulty component might be I have not real idea
Further.... since you have recapped check you have no shorts on psu rails this could be causing the PSU to shut its self down
I take it this is your MB Here
The three large ones are probably the on board Voltage Regulator (known as VRM)
Input caps the 10 (I think you said) are the output filter caps these should be low ESR types
the other two would probably be general purpose Electros
The behavior first posted is typical of bad caps or a failing supply caps
but its by no means the only cause
I suspect a problem with your recap at this point, causing the psu to shutdown
please recheck your solder work, cap placement and look for any solder Bridges
or solder splatter on the pcb.
A mag glass is very helpful here
lastly what caps did you use were? Thanks
There are others that would be more familiar with these MB and PSU then ILast edited by starfury1; 07-02-2007, 10:30 AM.You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
Oh yeah... i'd change the new caps on those three caps (1000uf 25V) with the rubycon one........still doesn't posting....what i afraid the psu got a problem cause i heard ticking sound came out from rellay or maybe the big Caps ....(tried without mobo)Comment
Ok Guys i tell step by step what i did...First My friend gimme the PC to install Vista ....and i install it ....it seems to be okay no problem.....later ,tommorow i started the pc and i get not posting , what im thinking is remove all the component and put it back...and yes its posting ...after that i shut down for 4 hours and then i boot it back it became not posting again....then i remove the ram it post ,but memory test fail....then i reconnect the ram...its beeping sound (RAM not availaible, 3 beeps) then after its ok ....(weird uh ..) then after a few hour.... i restart (cause installed a driver) then it became back not posting at all...after i tried to do what did i do before its still not posting....then i change the 10caps still the same ,change the 3 caps 1000uf 25V still same, change the 1000uF 10v still the same (not posting at all) and no beep, then heard very fast ticking sound came out from psu ( without plugged into the mobo) then suspect PSU ....and just now when i plugged into the mobo (its had ligth at the mobo ) but cannot started or turn on either.... now i really suspect the PSU problem.... :-(Comment
by iT0mT0mHi,
I have problem with detection RAM on this motherboard. When I install CPU(Ryzen 5 2600, 5 4500 or 5 5600G) DRAM Led is lighting all the time. I tried reflash various verion of bios using Q-Flash method and that not resolve my problem. I tried reflash bios by SVOD 4 but that not resolve problem too. All voltages is correct and I don't see any low resistance on coils and other elements on motherboard. I tried replace memory to other and nothing. I don't know where is a problem(maybe connections between cpu and rams socket?). Actually I have boardview for this motherboard and I have... -
This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...09-12-2024, 03:44 PM
This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...09-12-2024, 03:30 PM
by pkslowkSr. Motherboard Debug Error Code Solution
1 Intel 845 E9 Bios Related Problem
2 Intel 845 D4 CPU Socket Related problem
3 Intel 845 37 Bios Related Problem
4 Intel 845 7C Bios Related Problem
5 Intel 945GCPE 34 Bios Related Problem
6 Gigabyte 845 2 Ram Related Problem
7 IBM Server A6 A7 Ram Mismatch Problem
8 Asus 845 29 CPU Related Problem
9 Lenovo I946 97 C-Mos Jumper related
10 Gigabyte 845 A0 CPU Related Problem
11 Asrock G31M-VS D7 Bios Related Problem
12 Compaq 845 BD-70G B0 CPU Socket Related problem... -
by Xristakis795hi to all
I have the above motherboard on which I had windows xp I upgraded it to windows 10 everything went well just when it rebooted and got updates i saw a message for a very short time that windows is trying to fix a problem they found and then the problem was overcome and all is well
the computer works normally without any problems on the internet and in everything
but I found out unfortunately when I had completely cut off the power supply from the network and I went the next morning and plugged it in to turn it on when it went to boot a black screen and the cpu was working...12-28-2021, 06:24 AM - Loading...
