My caps esr levels: Tell me if there considered low..?
  • ChaosBlizzard
    • May 2004
    • 32
    The caps I have in use right now for my cpus are as follows:
    10 volts
    1500uf
    Impedance 100khz @ +20C Ohms max: 0.018
    Ripple current 1000khz @ +20C: 2470 mA
    The impedance/ohms are in the same collum as the same number..
    The series says "Low Impedance: 40-70% lower than FC series"
    Are the resistance levels on that (0.018) low enough?
    Thanks,
    CP
  • ChaosBlizzard
    • May 2004
    • 32
    Never mind.. I called Panasonic and they said my caps are will work well and not harm anything in a low esr inviroment.
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
