Panasonic capacitor date codes?
  • John843883
    • Nov 2012
    • 71
    Does anyone know how to correctly read the date codes on Panasonic capacitors?
    I have some just in and they all have "3206G" on them, surly they can't be from 2006? They are from Farnell who are a very reputable business in the UK.
    These particular capacitors are ECOS1HA103EA if that helps.
    Thanks!
    master hoarder
    • May 2008
    • 12175
    Re: Panasonic capacitor date codes?
    I've always wondered how to read the datecodes on Panasonic caps, too, especially some of the older ones with the red letters.
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • AleXis6
      Manufacturing Date of Electrolytic capacitor
      by AleXis6
      Guys. could you help me please to decode some codes of main capacitor's producers.
      I would like to know the manufacturing date.
      Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
      If I understood correctly:
      1. Nichicons marks date of production as (see the attached pictures) H2116
      I don't understand the meaning of first letter - may be it is code of factory.
      21 -year
      16 week
      I bought this capacitor recently.
      another one-
      2....
      10-11-2021, 02:20 PM
    • anty
      Lenovo Yoga 13 mb: Yoga 13 MB Panasonic capacitor identification
      by anty
      Panasonic capacitor identification...
      07-07-2023, 01:06 AM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
    • chth96
      by chth96
      06-02-2024, 07:31 PM
