Information needed???
  • wml52
    • May 2014
    I have an old Generac generator with a failed capacitor. The OEM part was a Facon capacitor p/n 7G75450N83 45uF +/- 5% 450 volt self-extinguishing generator run capacitor. It appears that this part is no longer available, I have found a few China made ccb60 series caps with the values I need but I don't know how reliable they would be? I did find many motor run caps with the same values but don't know if they would work in my genny. I figured I'd ask here since you have much more knowledge then I regarding capacitors so any information or thoughts would be appreciated.
    Thanks to all
    Wml52
  • proxneo
    Recapping Sony ICF-SW55 - verifying cap values
    by proxneo
    Dear reader
    I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
    At the moment, I have selected replacements based on the following list of values:
    3 x 470uF 10VDC
    3 x 4.7uF 35VDC
    4 x 47uF 50VDC
    8 x 22uF 6.3 VDC
    1 x 220uF 6.3VDC
    5 x 100uF 6.3VDC
    Which...
    06-21-2023, 12:38 AM
  • ongobongo
    Surface go 2/3 - resistor values needed
    by ongobongo
    I have a surface go 2/3 here which has problems with the battery showing/charging.
    I played around with the resistors on the back of the battery connector but forgot to take good measurements beforehand.
    can anyone help with the correct values of the attached resistors?
    thanks ongo...
    06-12-2024, 03:20 PM
  • rashidjafar
    Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
    by rashidjafar
    I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
    Values for :-
    PC43 : Capacitor [3x1.5mm]
    PL7 : Inductor [2x1mm]
    PC39 : Capacitor [1x0.5mm]
    Any ideas would be appreciated.
    I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
    08-07-2025, 05:10 PM
  • DeXXter
    HP VICTUS 16-d0500la Some Values
    by DeXXter
    Here some measurements on HP Victus 16-d0500la, it might help someone, the values are on diode mode->mV and some lower ones on Resistance->Ω.
    This specific laptop has an Intel i5 11400h + RTX 3050TI, the values are from a working laptop....
    03-13-2025, 03:16 AM
  • Dannyx
    Wind generator charger schematics (or load of baloney ?)
    by Dannyx
    Good day folks. A former colleague of mine recommended me to a relative of his and I got to speak to this man today in person. He's a bit of a mad scientist/tinkerer sort-of guy - just my kind of weirdo Apparently this chap builds all sorts of generators and wind turbines in his little shop at home and sells them here and there. He even showed me some footage of some of his inventions in action out in the field. However, as he himself very kindly put it, he's not good with electronics - he just designs and builds the generators (from scratch, I might add) and turns to others for the electronic...
    09-16-2022, 11:13 AM
