Hey guys,
I've recently purchased a graphics card which does not work. I've received a refund for it and I get to keep it. I've opened it up to find out that it seems the caps have leaked. I'm not too sure though because I thought solid caps did not leak but these look like they have rings of stuff around them on the PCB.
I have uploaded some pics in an imgur album. The pics are pretty bad. My camera is messed up and will not focus properly on the things in the middle of the image.
Anyway, here is the album: http://imgur.com/a/Ainfd
The 2 types of caps I think I need to replace are marked as follows:
ULR
16V
330
CV
and
ULR
2.5V
820
CO
I'm not sure either if this is the cause of the issue and if replacing the caps that appear to have leaked will fix it.
When plugged into a computer, the fans will spin and the computer will boot normally but the card is just never detected. I've tried it on a computer that had onboard graphics and it did boot Windows. The device manager wouldn't show anything and installing the drivers was a no go.
Any input is welcome. I would really appreciate a link to some capacitors that match the ones I need. I find it a bit overwhelming to shop on digikey with my limited knowledge on capacitors.
I'd also like to know what you guys think my odds are of bringing this thing back to life if I successfully change these caps.
Thank you very much for reading.
Edit: Card is a R9 290X, in case anyone wonders.
ULR
16V
330
CV
and
ULR
2.5V
820
CO
