Getting capacitors in GTA / Capacitor Brands
  • ToniCipriani
    • Sep 2004
    Anybody know where to get them in the Greater Toronto Area? It seems that getting these things here are way more difficult than in the US.
    Also, can anyone list which brand corresponds to which type I should get?
    e.g. (Panasonic -> FC Series, Rubycon -> JXA, etc.)
    Thanks!!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    www.digikey.com
    they're pricey for small quantities, but they should have what you need.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • cook
      Good brands of run capacitor for house heat hump
      by cook
      Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
      Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
      09-13-2024, 12:53 PM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
    • chth96
      by chth96
      06-02-2024, 07:31 PM
    • competition
      Replacing capacitors in Evga PSU
      by competition
      I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
      11-14-2025, 11:12 AM
