So it seems the standard pitch or lead-spacing on 10mm caps is 5mm and on 8mm caps it's 3.5mm.
I've just tried soldering a 10mm cap into an 8mm hole on my practice motherboard and it seemed to fit ok with the legs bending ever so slightly.
What concerns me though is that the cap will never sit totally flush with the board which means the leads will always be a bit longer than a like for like replacement.
Will the effects of the series inductance from the leads cause major issues here?
I've seen Topcat put 10mm caps into an Abit board and they look fine which is what convinced me to do the same.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
