"HELL" Inspiron 5100, could it be the caps??
  • doctorstrangelove
    • Apr 2007
    • 5
    Inspiron 5100.
    I was trying to get on the net true dial-up. And then he bluescreened on me. Tried to restart him but no luck. Powers up, the fan gives out warm air but the screen is black. Try 5 more times and no luck, almost gaved up. Though the mobo gone fry. But on the next try it went on!? Got to the loading windows screen and again bluescreened on me. Repeated same thing (5-7 times nothing and than again bluescreen)
    Anyway now it shows only blackscreen. Took out all the unnecessary parts to eliminate the problem. Tried different memory, nothing. Thought maybe BIOS got settings too high, so I desolder and solder back the BIOS battery to reset it. Still nothing. The CPU gets hot making me believe that it's ok. While I was taking BIOS battery out I inspected everything (the mobo,video,cpu) for signs of frying. Nothing seems fried.
    someone on craigslist told me to try on this forum with my problem.
    Could it be the bad caps??
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: "HELL" Inspiron 5100, could it be the caps??
    pic please
    • doctorstrangelove
      • Apr 2007
      • 5
      sry, don't have a digicam here. Visiting my motherland(Russia) for the next 6 mounth. If the problem in the caps, it would be great as I solder preaty good and here(in Russia) there is no problem in geting any electronic parts realy cheap. You can buy brand new "lamps" with no problem! Remember the ones you had in your old radio.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        what is the brand of the caps
        • doctorstrangelove
          • Apr 2007
          • 5
          I din't look at the caps. I haven't even thought about them until today felow cragslister told me to take a look at this site. Planing on taking laptop apart tomorow to take a look at it with caps in mind. Rightnow just wondering if this problem sounds like a badcaps.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            oh its a laptop
            you must look very carefully for components legs which solder is cracked from flexing of the case or desoldering from heat. (can you get it to work if you push on parts of the case?)
            you must also look for anything burnt or odd.
            its not so easy to troubleshoot laptop.
            • doctorstrangelove
              • Apr 2007
              • 5
              do you have a pic of caps that are used in laptops, can't remember seeing any regular size caps there when I took it apart.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                might be these http://www.capacitorlab.com/capacito...-smt/index.htm
                might be these http://www.capacitorlab.com/capacitor-types-polymer/
                might be these http://www.capacitorlab.com/capacito...-electrolytic/
                probably some of these also http://www.capacitorlab.com/capacito...-smt/index.htm
                who knows really. each board can be different
                dont get hung up on the caps. it could be some other problem.
                • doctorstrangelove
                  • Apr 2007
                  • 5
                  Yeah I have 2 of Chip Type SMT Electrolytic Capacitors and everything else is ceramic ones. Looked one more time for any visual damage around the whole motherboard, none were found.
                  Arr, so frustrating... It fires up, and everything seems to work. But does not work. So much easy on desktops when you have planty of spares, quickly pin point the problem. On laptops you realy don't have the oportunity to try different video or mobo etc.
                  will keep searching for the answer....
                  • stevo1210
                    • Oct 2006
                    • 4156
                    Originally posted by doctorstrangelove
                    Inspiron 5100.
                    Hello doctorstrangelove,
                    Your motherboard could be dead due to overheating maybe??
                    I read on the internet that the Dell Inspiron 5100 series had many issues with overheating and as a result the motherboard would be fried.
                    I think there's also a lawsuit aimed at Dell for improper design of the Inspiron 1100 and 5100 series notebooks.
                    Here are some links to some useful info about the Inspiron 5100 overheating problems.
                    http://en.wikipedia.org/wiki/Dell_Inspiron#Overheating
                    http://www.geocities.com/i5100dustproblem/
                    http://www.dellcommunity.com/support...message.id=329
                    Personally, I haven't seen or used an Inspiron 5100 notebook, but i've heard a lot of problems about it. I use an Inspiron 6400 and it is quite good.
                    Thanks.
                    • linuxguru
                      • Apr 2005
                      • 1564
                      I believe the Inspiron 1100 and 5100 used desktop P4 chips, not mobile P4s. As a result, the VRM as well as other subsystems in the power supply chain were prone to failure due to overheating/high currents.
                      • 13mh13
                        Dell Inspiron 5100 (2003) with RAM issues (voltage, PSU suspect ??)
                        by 13mh13
                        Here's my device:
                        LAPTOP: Dell Inspiron 5100 (2003) 2.4Ghz p4, dual-boot: Windows XP pro, sp1 + LinuxMint ( LM 17.1 MATE ), with 128GB ssd, 512mb ddr sodimm.
                        The 5100 runs fine, even after 19 years of daily, gentle use, "always on", and on adapter power only.
                        HOWEVER, over the past 5-6 years there has been a restart-up issue (after power down or power loss --- I leave all my PCs/laps in daily use in ALWAYS-ON condition, even going months w/o re-boots, but the inevitable always happens) .
                        Seconds to few mins after pressing the power button to restart...
                        06-06-2022, 08:44 PM
                        DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                        This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                        09-12-2024, 03:44 PM
                        DELL Inspiron 3650 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                        DELL Inspiron 3470 Inspiron 3000 i5-8400 Specification for Upgrade or Repair
                        This specification for the DELL Inspiron 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3470 boardview and Inspiron 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                        DELL Inspiron 3650 Inspiron i7-6700 Specification for Upgrade or Repair
