newbee capacitor samxon 150uf 450v
  • jimbob8467
    • Jan 2014
    • 9
    • England
    I am a newbee on here so if i am not supposed to be here then forgive me.cap 150uf 450v out of a 42inch lcd Toshiba TV all caps look good tests well i am a bit puzzled, this one gives me a reading of 137uf on the meter, the tv switches on ok then about a minute it will go off and 30 secs later will switch itself back on. The question..... is this cap ok or should it be replaced as i have read that as long as its within a 10% range it should be ok tested with newcason XC6013L setting on 200uf thanks. jimmy
  • jimbob8467
    • Jan 2014
    • 9
    • England
    Re: newbee capacitor samxon 150uf 450v
    might answer my own question here did not see the HP(M) on the cap believe giving it 20% is this correct????
    • Sparkey55
      • Jan 2010
      • 1523
      Usually -10% to +20% tolerance. 137uf sounds right to me.
      • jimbob8467
        • Jan 2014
        • 9
        • England
        thankyou for your reply
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
