I have a Delta PSU, a DPS-370AB A Rev 01F in fact.
It uses a mixture of Nichicon, UCC, LTec and wait for it... CapXon.
Delta! You should know better... and in an HP server too...
Guess which capacitor is bulging?
Due to the dimensions of the CapXon (GL Series: 0.024 ESR), the replacement comes down to Panasonic FC and Rubycon ZL. The ZL is cheaper since I don't have to buy in bulk. Imagine that. Saving money on GOOD parts!
The FC matches RCR and ESR closely: 0.022 Ohm
The ZL has much better RCR and ESR lower: 0.015 Ohm
I know if you lower ESR too much in PSUs you actually get more ripple. Considering that the Rubycon is probably half or more than half less ESR than the CapXon, is it OK to use? Or do you have to *seriously* decrease ESR to Solid Polymer levels to cause these kinds of problems?
