is this leakage acidic or alkanine caustic?
  • theOracle
    • Nov 2012
    • 163
    Often see this brown leakage from Nichicon PF series (quaternary ammonium salt compounds type) from the 1990's
    is this leakage acidic or alkaline caustic?
    __________________
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: is this leakage acidic or alkanine caustic?
    Ammonium chloride reacts with a strong base, e.g. sodium hydroxide, to release ammonia gas:
    NH4Cl + NaOH → NH3 + NaCl + H2O
    probably a weak acid, but don't hold me to it i only got a low passing grade in chemistry.
    Follow the white rabbit.
    • petehall347
      anyone recommend an earth leakage clamp meter ?
      by petehall347
      have been looking at earth leakage clamp meters and its like a minefield out there . i wondered if anyone here had bought one that actually works properly ?...
      04-17-2024, 01:31 PM
    • прямо
      Corsair HX 750W - DC Leakage at 12V Output Rail in Standby Mode
      by прямо
      Just received it today from a friend.
      Auto shutdown by the supervisor IC because of an under voltage condition with 12V output rail (dropped to 10.5V)
      The same rail also does this when the PSU is in standby mode.
      https://ibb.co/5TBkg66
      The leakage keeps climbing at a steady rate but slowing down when it reaches over 800mV or so. I didn't measure exactly at what value it stopped or if it's even stopped at all.
      What could have caused that?
      First time I have seen such behavior.
      3.3V and 5V rails don't have the same...
      02-19-2024, 09:52 PM
    • titomno2
      DELL LATITUDE E5450 - +RTC_CELL Leakage
      by titomno2
      Motherboard (ZAM70 LA-A901P Dell Latitude E5450) not starting (no short on the main line).
      When insert ac plug I have noticed the PU100 is hot, 3.3V is only 1.05V (may vary a bit) and also PD3 is hot.
      I firstly removed PC1 (after wrongly mesured a short to ground) => Still PD3 ot.
      I replace PC1 (when my mistake discovered) => Still PD3 hot.
      I removed PD3 and PR1 (PU100 is fine and I can mesure the 5V and 3.3V correctly), I presume there is a leakage on +RTC_CELL.
      So I use BoardViewer 2.0.1.9 (Beta) which is a great tool and cad of ZAM70 LA-A901P...
      08-29-2021, 10:01 AM
    • trufla
      Current leakage MS-16J91
      by trufla
      Hello !
      Got a dead laptop not turning on due to shorted main power delivery rail mosfets. The mosfets have been replaced and the laptop turns on and posts now but here comes the train... Now there is a current leakage somewhere... I can feel the electricity when i touch the heat sinks ... Note: heat sink screwed in to the boards ground. Any idead where to look for a cause of this issue ?
      Any input much appreciated !
      03-28-2021, 07:59 AM
    • jj5
      Cleaning up capacitor leakage
      by jj5
      I'm doing some OGXbox refurbs and the clock capacitors (PowerStor Aerogel) notoriously leak all over the board. I'm not sure what you call the electrolytic fluid which comes out and gets all over the circuit board, but I would like to know the best process for cleaning it up. Should I hit it with vinegar or isopropyl? Or both? Or something else?
      06-21-2022, 12:16 AM
