647-UHM0J102MPD3 Nichicon 6.3v 1000uf from Mouser swiftly bad
  • mrmazda
    MrMazda
    • Sep 2013
    • 115
    Tiny as these and the text on them is, even with magnification, I doubt whether I would be able to tell whether they are genuine.
    I bought 10 in July of 2008, 10 more June of 2011, and 40 early last month. IIRC (far from guaranteed), when the newest arrived I mixed them with the remainder, then installed 17 in an Asrock K7Upgrade-880. 23 new remain in the bag.
    Several days ago the Asrock was still working. Today it will not POST. 9 of the new caps are no longer flat on top already. 2 between CPU socket and rear panel ports are oozing yellow.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: 647-UHM0J102MPD3 Nichicon 6.3v 1000uf from Mouser swiftly bad
    you probably installed them backwards.
    asrock/asus marks them backwards.
    • mrmazda
      MrMazda
      • Sep 2013
      • 115
      Yikes! Are there manufacturers of other products setting this n00by trap? Posting and running normally with 18 of them installed backwards I find hard to believe. Uptime functioning properly since their replacement was surely more than 10 hours, maybe twice that. Yet, replacing all again but with polarity reversed WRT labels like those I did not change, it's running again. Is reversed polarity responsible for the swelling, or could I have gotten a bad batch?
      • mariushm
        • May 2011
        • 3799
        Reverse polarity is definitely a cause for them swelling... you're lucky they lasted that long and didn't just pop their tops.
        • Heihachi_73
          • Jun 2012
          • 713
          Nichicon quality. If it was cheap junk from RadioShack (Australian equivalent is Jaycar) they would have been lucky to last 2 minutes.
          I will confirm, my ASRock N68-S3 board has "reversed" markings - its original caps have the negative stripe on the non-shaded side.
          • PeteS in CA
            • Aug 2005
            • 3583
            • USA, Unsure of Planet
            Indeed, H_73! Reverse-installed electrolytics tend to be noisy, messy, and often they launch. When I worked at Boschert (a 70s-80s P/S company) the ceiling tile above what had been the manufacturing test area had lots of circular holes, some with caps still embedded. Also while I was at Boschert, a guy working at the bench next to mine applied 48V to a board in which the assembler had accidentally installed a 7.5V part (same size and color). The cap launched and hit him in the chest. He wasn't hurt, but I didn't see him in the lab for the net hour or so.
            PeteS in CA
            • DrewPhillips
              Capacitor Diarrhea - Nichicon PL Series
              by DrewPhillips
              Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
              The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
              03-02-2025, 10:18 PM
            • gabrieljma1
              Request: Full BIOS dump for ASRock Z790-CX (DDR5)
              by gabrieljma1
              I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
              The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
              I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
              10-08-2025, 03:32 PM
            • nick3092
              Mid/late 80's Nichicon Yellow Caps
              by nick3092
              I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
              08-28-2022, 03:56 PM
            • Exim
              ASRock N100M, no picture no boot, but semi-alive
              by Exim
              Hi guys,
              I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
              ASRock N100M special features:
              - CPU soldered to board, small Intel 12th gen
              - iGPU
              - four POST LEDs
              Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
              I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
              Symptoms:
              - no picture/signal on any of the display connectors,...
              04-01-2025, 02:36 PM
            • MasterCap
              What IC does AsRock usually use to make the PWM signals for GPU fans ?
              by MasterCap
              I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
              Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
              But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
              12-28-2024, 08:42 AM
