Recapping monitors and PSU
  • c_hegge
    replied
    Re: Recapping monitors and PSU
    Try to match the original caps (or get close). If they are GP caps, then go with 'entry level' Low ESR caps (Panasonic FC, Nichicon PW, or Chemi-con LXZ)
  • dealova
    replied
    Thanks guys. Is there any clue what's the minimum impedance I should take ? above 0.10 ohm perhaps ?
  • ben7
    replied
    Originally posted by mariushm
    The dc-dc converters on motherboards and video cards usually run at 500kHz or more, sometimes they even switch at more than 1 Mhz.
    Switching power supplies run at high frequencies but not quite as high as those found on motherboards... usually, they work at around 50-80 kHz and higher.
    Monitors use switching power supplies to get the voltages they need, computer power supplies are switching power supplies and so on.
    Just like with motherboards, low esr and high ripple capacitors are very recommended but you have to pay attention because the circuit can be designed to work with capacitors that have an esr value that's a bit higher compared to the esr of capacitors you would find on motherboards.
    These capacitors would still be considered "low esr" but have worse ESR compared to those series of capacitors usually found on motherboards.
    So you do have to check the datasheets and not just use the best possible capacitor which you would stock for servicing motherboards or video cards. Doing so may make the power supply unstable or noisy or die sooner than expected.
    LOL you pretty much said exactly what I said...
  • mariushm
    replied
  • ben7
    replied
    Preferrably, yes.
    BUT, don't put capacitors with very very low ESR in the power supplies. The low ESR may make the power supply unstable, causing an audible whine or buzzing. This also creates more voltage fluctuations on the output. You see, PSUs are designed to use certain capacitors, not just any plain ol' ones!
  • dealova
    started a topic Recapping monitors and PSU
    Do we need to use Low ESR & High ripple caps for LCD/LED monitors & computer's power supply ? Or only for motherboards. Thanks.
  • SwedishDiesel
    Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
    by SwedishDiesel
    Howdy folks,
    I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
    10-30-2021, 12:47 AM
    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
    by sam_sam_sam
    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
    I tested the battery cells there are installed right now and they are testing good with no issues that I...
    02-04-2025, 08:08 PM
  • DynaxSC
    Extreme High Current & Low Voltage Short Killer ??
    by DynaxSC
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
    10-15-2024, 10:13 AM
  • harp
    high voltage high resistance marking resistor
    by harp
    Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
    08-26-2024, 01:42 PM
  • Rayblaster
    HP RP7 RP7800 from 2012/2013 worst fault - has "character"
    by Rayblaster
    Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
    I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
    12-30-2024, 06:28 PM
