Does my CD-RW drive possibly have faulty capacitors?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    BTW, does a CD drive even have any capacitors? Anyway, I have been getting the following symptoms with my CD-RW drive:
    It basically only works like a CD-ROM drive now!!! :evil:
    I will always get an error message during the burning process, no matter if I'm using Nero or the CD burning software that comes with Windows XP.
    Under Nero, I usually get an error message about a focus error or a cannot perform fixiation error.
    Under the Windows XP CD burning wizard, Windows XP ALWAYS bitches at me, with the message stating that it cannot complete.
    Lately, ALWAYS major errors. :evil:
    BTW, I installed everything properly and even made sure the ASPI layer was installed. Inserting a blank CD, at least sometimes will cause Windows to lock up.
    Also, Windows at least randomly will basically say that the CD I inserted is a CD-ROM!!! :evil:
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    you could look for bulging caps but i doubt that is the problem.
    a bad laser or fouled optics is much more likely.esp if you smoke around it.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      No. I don't smoke. Never have, never will. The symptoms just started occuring two springs ago.
      Arc A770 16 GB
      • JarzabekPZ
        HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
        by JarzabekPZ
        I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
        08-08-2025, 03:40 AM
      • Spudgun
        Why doesn't current just bypass faulty capacitors.
        by Spudgun
        Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
        04-01-2025, 10:33 AM
      • b-slayer
        Acer A317-53 need help to disable faulty onboard ram
        by b-slayer
        Hello.
        I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
        - first one is to modify le bios to disable the onboard ram.
        - second one is to disable the onboard ram by desoldering some components on the mainboard.
        so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
        so i found that my motherboard...
        10-12-2024, 03:46 AM
      • brispuss
        Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
        by brispuss
        Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
        Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
        I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
        12-28-2022, 02:58 AM
      • nrj1982
        Lenovo Ideapad3 NM-C821 faulty motherboard
        by nrj1982
        Hello all,
        I have a Lenovo Ideapad3 laptop, that has recently stopped working. When pressing the power button, the led is going on, but nothing else is happening.
        I have checked the 3.3V, 5V and 20V - all of them seem present (checked with multimeter and oscilloscope in order to verify that they are stable).
        I have checked the voltages around PU1901 - 0.9V, 1.8V, 5V, 2.5v, 0.6V and 1.2V - all of them are present.
        Now going further in the debug, I found that the CPU voltages produced by RT3662AC (PU5901) PWM driver are missing. I can see that the 20V...
        10-04-2025, 10:08 AM
