I've got an older Asante FR1104G router cracked open as it's out of its warranty period. It was always flakey, even the ones sent back as in-warranty replacements. There are 16 identical 47uF 16v caps with a strange branding. They are black with white lettering and the brand logo is a lightening bolt with a stylized "SC" next to it. I've got some Nichicon HE's left for this project, but I was curious if anyone has come across this specific brand of capacitor before.
Anyone ever seen these caps?
Re: Anyone ever seen these caps?
Post up some pics if you can, they don't sound familiar.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
Alright, here it is. I scaled the photo size down but you should still be able to see it. I can't determine whether these caps are a known bad brand or not. The router works, but it will periodically lock up and stop routing packets.Attached Filesif you find these attachements useful please consider making a small donation to the site
I found these 'SC' caps inside my old wireless router. The router kept having problems and then finally stopped working altogether. Opening it up, I didn't see any bulged or vented caps, but I did see this 'SC' brand - and that the power diode was sparking when I applied power.
I was also surprised that it used a standard wireless PCMCIA card for the wi-fi services, connected to the external antenna! I've now replaced it with a new-model router (same manufacturer though), and it's still working today.You know there's something wrong when you open your PC and it has vented Rubycons...Comment
I think I have a positive ID on these. I ran across these caps today at work:
The wrapper color is different from Kacerdias's description but the logo sounds the same. Who are they? The source is Surge Components, who sells Lelon here in the US. So these are rebranded Lelon caps. Notice the use of a Nichicon series name, "PW". Also note the lack of any date code or factory code info. When I unwrapped a sample, I found (through a rudimentary test) that, despite the me-too use of a Nichicon non-aqueous series name, the electrolyte is aqueous. This was not the first time I'd found Lelon fudging or failing to control the electrolyte type.Emerald green wrapper
Logo – Single zigzag lightening bolt followed by a stylized “SC”
“330uF 16V”
“105C Vent”
Gold polarity stripe with inset arrow and “-“ symbols
“PW”
“L.E.S.R.”
No fate code or factory code
Bung has two concentric rings with slight clearance for cleaning around the leads; the wrapper, not the bung will be in contact with the PCB.
“X” vent on can top.PeteS in CA
****************************Comment
"fate code"? I promise, that was a Freudian Typo, however appropriate it may have been.PeteS in CA
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
