System stability and PSUs
  • Tom41
    • Oct 2005
    • 336
    • England
    As I mentioned in a much earlier 'bad caps irony' thread, it's possible to have many capacitors fail and the system still be stable. On the other hand, you can have one tiny little bulge on a single cap, and the system will reboot constantly (both have happened to me).
    What I'm really asking here is that if a PSU cap fails and it starts outputting 'dirty' power, can that be used as a measure of how good the caps on the motherboard are?
    If, for example, you apply dirty power to a board and it remains stable, you have good caps and/or a well designed board. On the other hand, if applying dirty power makes the system unstable, the caps on the board might be bad as well (or the system is under stress).
    I know it's probably not recommended to put dirty power into a motherboard, but can it be used as a test to see if your system is under stress and/or has caps prone to failure? My 2.2GHz machine is packed with genuine Rubycon caps, and yet 'dirty' power caused it to constantly reboot
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: System stability and PSUs
    your problem is still undefined. is it packed with rubycons everywhere? then you probably have some other problem with the board.
    an esr meter would be useful to check the caps in this instance..
    • yanz
      • Nov 2004
      • 910
      dirty power can kill easily any good caps. that was i always worry of. if i recap the mobo, but left the bad caps on the psu, then.. screw me! recapping the mobo and psu is one packet to do, imho.
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
        EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
        by momaka
        I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
        So, here is the...
        06-06-2020, 04:39 PM
