I am telling you guys. Got this Acer AL1916W A which was blinking like christmass tree to repair. Full of Su'scons SGs, 470 uF/25V, one 1000 uF/25 V. I replaced them on sight (some Chemi-Cons KY 1500 uF/6,3 V and LXZ 1000 uF/25 V) and it is fine now.
But one problem is, according to ESR Micro v4.0 they are in 100+% condition. I mean, ESR was just OK (around 0,04) with capacitance slightly higher than nominal. Supposedly the display started to work OK when it was heated up, but it is not like they are bad when cold and get better when heated. I measured them at room temperature and I am telling you, according to these readings they are just fine. What am I missing?
Half of the computer problems is caused by bad contacts
