Tilted caps on modem normal?
  • george-JL
    • Dec 2006
    My 56k internal modem has a few small skinny capacitors which are tilted at a slight angle, but not swelling or oozing any liquid. It still works at this point.
    The weird thing was when I looked on the packaging box of the modem, it has a photo of the modem with tilted capacitors clearly visible .
    Just wondering if this is a normal thing?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Tilted caps on modem normal?
    It's normal for those little skinny ones. The slightest touch causes them to move, unlike larger ones.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • george-JL
      • Dec 2006
      Thanks .
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
