Recommendations for 22μF 16V capacitor
  • jpyerry
    • 94
    I have a motherboard that has a few 22μF 16V capacitors on it, they are S.I. branded with no series identifier, only that they are 105°C rated. I know that these are probably too small to need recapping, but one snapped off and will need to be replaced. Does anybody have a recommendation on brands and series to consider for replacing this capacitor?
    Thanks,
    Justin
  • Difficilus
    • Dec 2012
    • 19
    Re: Recommendations for 22μF 16V capacitor
    Thanks,
    Justin
    Most everyone here likes Panasonic FC or FM series caps.
    • mockingbird
      • Dec 2008
      • 5484
      Here you go:
      http://www.digikey.com/product-detai...1769-ND/589510
      • jpyerry
        • 94
        Thanks for the replies!
        @Difficilus - Neither the FC nor FM lines are made with a 22μF 16V capacitor.
        @mockingbird - I read somewhere on this forum that the Nichicon PW are not suitable for PC motherboard usage, I don't know if that individual was mistaken or not.
        One last question, would I be better off using a 22μF 50V capacitor from a low ESR series like the Panasonic FC or FR series, or would it really matter in this instance?
        Justin
        • mariushm
          • May 2011
          • 3799
          The motherboard has several areas in which capacitors are used.
          Some sections (like the area near the cpu which gives power to it and the area very close to the memory modules) require high quality capacitors with very low ESR, in which case Nichicon PW series is not suitable.
          However, in these kind of sections it's unlikely that 22uF capacitors were used, and even so they weren't very low ESR in the first place.
          So these capacitors were either in some areas that don't require high end capacitors or the designers of the board determined general purpose capacitors were OK to be used there.
          Nichicon PW series will be ok.
          Panasonic PC will also work, Rubycon ZLG will do just fine.
          If you can't find in stock capacitors rated for 16v, you can go for 25v rated capacitors without any worries, except paying attention to the diameter of the capacitors (you want them to fit on the board)
          As for: would I be better off using a 22μF 50V capacitor from a low ESR series like the Panasonic FC or FR series, or would it really matter in this instance?
          FC is not really that low esr, it was a low esr capacitor years ago but what they considered low esr then is now just average. FR is much better than FC at the ESR.
          I don't think it would affect the board and how it works, if you go for FR or FM series from Panasonic, but you have Nichicon PW and FC which are just less to worry about.
          • jpyerry
            • 94
            Thanks everybody, I will give the Nichicon PW a try then.
            Justin
            • MORETTIGIAN
              by MORETTIGIAN
              Title:
              Description:
              Procedure performed:
              - Removed backplate
              - Reapplied thermal compound
              - Reassembled card
              09-18-2025, 12:14 PM
            • Prolog
              by Prolog
              12-01-2024, 08:27 PM
            • chth96
              by chth96
              12-22-2023, 04:34 AM
            • chth96
              by chth96
              06-02-2024, 07:31 PM
            • chth96
              Is it no harm to replace with capacitor without ripple current rating?
              by chth96
              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
              Rubycon YK DataSheet (b...
              04-19-2024, 05:19 AM
