Ouch!!! Gigabyte using FAKE CAPS?!
  • Shocker
    Banned
    • Dec 2011
    • 635
    Re: Ouch!!! Gigabyte using FAKE CAPS?!
    That's usually why controller boards on external hard drives die - cheap capacitors that get scant airflow if any atop that.
    Hmm...maybe I'll get another one later on and recap it. And would you suggest using special 125°C caps???
    Well, I've had notebook drives last longer than that and they're much, much lighter.. I'm willing to bet that it's because A) Maxtor drives ran hot and B) Maxtor drives are trash. And yes, heat could be the cause of that board's failure.
    To be fair, smaller and thinner drives are obviously expected to be lighter. I do have an old, thicker drive (from a Pentium MMX Toshiba laptop - back then they used OS-CONs ). But 2.1GB isn't much use today and it isn't quiet.
    This Maxtor, on the other hand, has no such excuse. The curious thing is I found two unused holes that could have been for a much larger board. I didn't think it got hot. So that leaves B - Maxtor drives are trash. I suppose. With the later "9" series they added five reinforcement ridges extending from the spindle motor to the edges of the drive. Those later drives are heavier than the earlier "8" series (but still not comparable to Barracuda ATA IV/V/7200.7).
    Quantum drives underwent a similar change going from the "SE" (2.1GB/platter) to the "EL" (2.5GB/platter). I have a 5.1GB EL by the way, along with a 6.4GB EX (3.4GB/platter) and a 4.3GB CR (4.3GB/platter). I can't stand the racket but otherwise have no problems with them.
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      Putting a fan over the controller board would help.
      Or 7200.8-7200.9 Barracudas which are just as heavy. But I've heard that Maxtor PCBs are mounted in such a way that they run hotter and get less airflow.
      OS-CONs are very good - too bad that Gigabyte board had fakes.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Got some pics?
        Muh-soggy-knee
        • Shocker
          Banned
          • Dec 2011
          • 635
          Can't find the SD card
          • Shocker
            Banned
            • Dec 2011
            • 635
            And here comes the scary part - 4 Supacons in the VRM and none bloated.
            • c_hegge
              • Sep 2009
              • 5219
              Problem solved
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Wow!!!
                Supacon caps look similar to rubycon MBZ
                Originally posted by c_hegge
                Muh-soggy-knee
                • KKvantas
                  • Sep 2013
                  • 17
                  • US
                  #28
                  My GA-78LMT-S2 had fake Suncons/Sanyos on them.
                  • mariushm
                    • May 2011
                    • 3799
                    #29
                    What makes you think they're fake?
                    I don't know Gigabyte as a company that would stoop to using fake capacitors.
                    • DynaxSC
                      GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                      by DynaxSC
                      I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                      General test conditions:
                      - Tested with Core i5 6500 and Core I7 6700K - no difference
                      - Default BIOS settings, but tried also altering several memory setting - does not change anything
                      What is wrong:
                      With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                      When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                      03-21-2025, 06:23 PM
                      Thermal pad thickness for various laptop GPU / Graphics Cards
                      ASUS Dual RTX 2070 OC 8GB
                      ASUS ROG STRIX RTX 3080 OC
                      ASUS ROG STRIX RTX 3090
                      ASUS TUF Gaming RTX 3080 OC Edition
                      ASUS TUF GTX 1660 S-O6G GAMING
                      EVGA RTX 3060 Ti XC GAMING 8GB
                      EVGA RTX 3060 XC GAMING 12GB GDDR6
                      EVGA RTX 3080 FTW3 ULTRA GAMING
                      EVGA RTX 3080 TI FTW3 ULTRA GAMING
                      EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                      Gainward RTX 2080 Phoenix GS Specs
                      Gainward RTX 3070 Phoenix 8GB
                      Gainward RTX 3080 Ti Phoenix
                      GIGABYTE AORUS RTX 3080 MASTER 10G
                      02-09-2024, 08:08 AM
                      A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                      by momaka
                      More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                      And a shot of the label:...
                      01-26-2022, 03:26 AM
                    • nikovmiroslav
                      Gigabyte A5 X1 Need Bios
                      by nikovmiroslav
                      Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                      Gigabyte A5 X1
                      From motherboard:
                      S/N: 1TNH55ER1350895
                      P/N: 6-77-NH55ERQY-D02-2CGB
                      On sticker from the back of the laptop:
                      S/N: SN21351J000657...
                      08-24-2025, 09:15 AM
                      Gigabyte 7X Notebook Specification for Upgrade or Repair
                      This specification for the Gigabyte 7X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7X boardview and 7X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte 7X Notebook is accurate,...
                      09-07-2024, 07:19 AM
