Acer Motherboard AM1640 and AM5640
  • Swordnova
    • Jun 2012
    Hi All ,
    I am new in this forum and new in recapping motherboard . I have 4 pcs of the same motherboard and all 4 have the same problem it dont have video . I test with video card in PCIE not work , check memory and PSU nothing it is possible it a capacitor it dead . I check the capacitor in the board and it like to not have burn . Do you have idea what it can do that . When i remove the 2 memory dimm it dont have bip or something . Thanks for your help and have a good day
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Acer Motherboard AM1640 and AM5640
    Did you buy them as non working motherboards?
    Did you try without a videocard - just using onboard graphics.
    Does the fan start - does the hard disk start.
    Do you get any led lights?
    Did the pc work with a good motherboard?
    Have you tried the memory in another machine?
    Cleaned the memory slots and pins on the memory stick?
    • Swordnova
      • Jun 2012
      Hi
      For reply to your question
      It all 4 computer that customer have for repair and i change the board for new one it already not working .
      It not work with onboard and PCIE graphic card
      The cpu start and hard drive too but no post and no bip
      Just the power blue light
      Yes it work with new board like asus 775 with same cpu and memory and hdd
      Yes and work
      • retiredcaps
        • Apr 2010
        • 9271
        Search is your friend ...
        https://www.badcaps.net/forum/showthread.php?t=16609
        And yes, the motherboard still works today.
        --- begin sig file ---
        --- end sig file ---
        • mockingbird
          • Dec 2008
          • 5484
          _Don't_ reflow these chips, it is a waste of time.
          Let me explain why...
          Normally, what you try to achieve with a reflow is to bond the leads of the chip to the pad on the board... What people don't realize, is that what they are really accomplishing with these nVidia chip reflows is the re-bonding of the *internal* pads from the core to the substrate. They're seperating because nVidia used an inappropriate combination of solder alloy for the substrate and core pads.
          Even "re-balling" will never make these chips completely reliable.
          If you reflow, you're only buying yourself some more time.
