What other brands are on the same level as Jun Fu? I know they can't be that good. My buddy gave me his PSU cause he wanted a better one (it maybe got a week of use) and it has ALL Jun Fu caps, rated at 105C....It's a Lepa N500. It's still under warranty. Would this little guy be okay powering a small system? Should I wait till it's out of warranty to recap it? I think its OEM is CWT.
What can you compare Jun Fu caps to?
by Perry BabinI have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
If not organic polymer, what would be the caps that could take the most abuse?-
by eryjusHello,
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
- Loading...
