VA902b Shakey jittery image
  • blues
    • Apr 2012
    • 19
    • CAN
    Newbie here, I have a viewsonic VA902b monitor that powers on and shows video output, but the screen looks shakey, jittery, like electrical interference. I chacked all cords and connections and replaced cords, all without resolution. Is this possibly a bad capacitor problem?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: VA902b Shakey jittery image
    Yes, it could be. Take apart the monitor and have a look. Even if it is not, try reseating and cleaning every connector.
    --- begin sig file ---
    --- end sig file ---
    • blues
      • Apr 2012
      • 19
      • CAN
      I followed your advice, but still experience a problem. None of the caps look bloated or leaking to me. Any suggestions of where to start? I have a 40W iron and a multi-meter. I have attached some pictures, I hope they are clear enough and that I have followed the requirments for uploading.
      • selldoor
        Slow Learner
        • 7870
        Hi - you have su'scon caps on the power board which is possibly the cause of unsteady voltages. Also on the back of the power board can you check the joints where the mains plug is - it just looks a bit odd in the picture - perhaps you can do a close up.
        I dont know if you have worked on open boards before but there are voltages in the region of 300-400 volts so you need to be careful.
        First can you measure the voltages at the connector at the top right in pic 2 and post your results. Then do it again with it all set up and working - take care that boards do not touch and you are working on a non conductive surface.
        • blues
          • Apr 2012
          • 19
          • CAN
          Thanks. Total newbie here, wondering how to test with my multi-meter. Pins 1 & 2 are VCC5V. Do I touch the other end to GND pin 6? Also more pics attached.
          • selldoor
            Slow Learner
            • 7870
            Yes - you can use 3 or 6 as ground
            Set meter on Volts DC - red (positive )probe on pin being tested Black (Negative) probe on gnd.
            Thanks for pics - mains pins look ok - trick of the light.
            • blues
              • Apr 2012
              • 19
              • CAN
              Help can't find replacement cap for 100 uF 450V, anyone?
              • selldoor
                Slow Learner
                • 7870
                Wouldnt worry about replacing if it doesnt look bulged or leaky the big ones are usually ok.
                If it becomes necessary we will come up with a suitable alternative.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Lots over at digikey, but before replacing any caps, what are your voltage readings?
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    I prefer to use a ground screw closest to the measurement point. That way, there is no risk of both probes touching and possibly shorting out something.
                    • jetadm123
                      • 2169
                      If you find no issues with the power board, then I would suggest replacing the 6 caps on your logic board. Since these caps have a higher capacitance valure and are physically smaller, they tend to dry out more quickly.
                      • blues
                        • Apr 2012
                        • 19
                        • CAN
                        Pins 1 and 2 both read .0005 or was it .005 for both pins with capacitor in-line and power off. I have not yet getermined the readings with power due to my poor lighting. I bought a decent worklamp today, hoping to get readings tonight.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Circled in red are two voltage regulators.
                          1) Measure the DC voltage of bottom 3 pins (ignore the fat tab). Use a ground screw on the logic board for ground (black probe).
                          2) Report the part number and your measurements like
                          Part number = AL1117-33
                          pin 1 = 0.0
                          pin 2 = 3.3
                          pin 3 = 5.0
                          • blues
                            • Apr 2012
                            • 19
                            • CAN
                            Do I need to connect this board to the power board and plug in AC to measure the DC here?
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Yes connect both boards. All voltage measurements require the lcd to be plugged in and powered on.
                              • blues
                                • Apr 2012
                                • 19
                                • CAN
                                They are marked as follows:
                                Part number AL1117-33 (position of component is below, slightly left)
                                pin 3 = 5
                                pin 2 = 3
                                pin 1 = 0
                                Part number AS1117-18 (position of component is above)
                                Pin 3 = 5
                                pin 2 = 1
                                pin 1 = 0
                                The values are read on an analog meter and are not exact. Taken with power on the board.
                                • blues
                                  • Apr 2012
                                  • 19
                                  • CAN
                                  Sorry, didn't get your response until after I posted. Do you need me to re-take them with the LCD wires connected?
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    pin 3 = 5
                                    pin 2 = 3
                                    pin 1 = 0
                                    Pin 3 = 5
                                    pin 2 = 1
                                    pin 1 = 0
                                    Voltage regulators are usually +/- 1% of their stated output. The suffix in the AL1117- part number denotes the expected output voltage. For example, AS1117-18 denotes 1.8V DC output.
                                    With your analog multimeter readings, both regulators would be bad.
                                    It would help to redo the readings with a digital multimeter.
                                    • blues
                                      • Apr 2012
                                      • 19
                                      • CAN
                                      pin 3 = 5.10
                                      pin 2 = 3.30
                                      pin 1 = 0.00
                                      Pin 3 = 5.05
                                      pin 2 = 1.24
                                      pin 1 = 0.00
                                      power was on all connectors connected.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        Pin 3 = 5.05
                                        pin 2 = 1.24
                                        pin 1 = 0.00
                                        AS1117-18 is definitely bad and probably the cause of your shaky images.
                                        The fixed 1.8V regulator is a highly used part so it should be available at your local favourite electronics store. If you have old junk boards, you can look there and reuse the old one. I found one on my old sound card.
                                        Otherwise, order online, but ordering from digikey, mouser, etc is going to cost you $8 USD in just shipping/handling.
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 10:56 AM
                                          HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
