will this capacitor work?
  • h0t3r
    • Apr 2012
    I'm replacing capacitors on a motherboard.
    In replacing some 1000uf 6.3v caps, the old ones are marked:
    RLX
    105C
    0519
    My replacement caps are marked:
    RLS
    105c
    0312
    Will they work? I don't know what RLX or RLS mean and I don't know what the 0519 and 0312 are. Can anyone explain them to me or give their opinion? Thanks.
  • mariushm
    • May 2011
    • 3799
    Re: will this capacitor work?
    RLX and RLS are two series of capacitors made by a company called OST.
    0518 and 0312 are probably date codes. As in 05 = 2005, 18 = week 18
    OST is not a particularly good brand of capacitors and they tend to go bad when used in areas where there's lots of heat (near processors for example), often without showing any signs of failure.
    So personally, I wouldn't recommend them.
    The RLX datasheet is here:
    The RLS datasheet is here:
    According to the datasheet, the RLX caps are 10x16mm , 0.034 ohm impedance, 1540 mA ripple.
    You need to replace these with ones that fit the area, with lower or equal impedance than the ones you have, and equal or higher ripple value.
    In the largest can size, 1000uF 6.3v RLS has 0.053 ohm impedance and 1030mA ripple, both below what you need. So, it's not recommended.
    As a tip, you can always pick a capacitor rated for higher voltage, as they usually have better specs but they're usually taller or wider.
    Since you're in US, a good store to buy would this site's store, or Digikey.com
    On Digikey, these will work for you:
    http://search.digikey.com/us/en/prod...2353-ND/613714
    http://search.digikey.com/us/en/prod...PD9-ND/2428117
    http://search.digikey.com/us/en/prod...2354-ND/613715
    http://search.digikey.com/us/en/prod...MPD-ND/2428129
    http://search.digikey.com/us/en/prod...1646-ND/756162
    The ones towards the end as you can have a slightly lower ripple value than the OST specs but I trust these brands more than I trust OST listing accurate values in the datasheet, so I believe they're good enough.
    PS. If the capacitors are grouped together and some are bad while others aren't showing any signs, you should replace all in the group anyway - the others you won't replace will die soon.
    • h0t3r
      • Apr 2012
      Thanks so much for the info! I appreciate it.
      • John Doe
        • Apr 2012
        • 3
        • Rhode Island
        RLS (brown ones) are good caps. FSP used them in the ProXStream 1000 and they've shown to be sufficiently reliable and decent.
        RSX (blue ones) are junk though, they caused the failures of many Topower units.
        If you can, replace them all with RLS. If not, don't mix the two as it'd make things worse. In that case, get rid of them all as he pointed out.
        • MORETTIGIAN
          Capacitor detached from PCB – RTX 2070 Super Founders Edition
          by MORETTIGIAN
          Title:
          Description:
          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
          I did not notice it detaching, so I am unsure of its original location on the PCB.
          Procedure performed:
          - Removed backplate
          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
          - Reapplied thermal compound
          - Reassembled card
          Observed behavior after reassembly:
          - GPU powers on and operates normally under...
          09-18-2025, 12:14 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • corrize
          Nikon D800 camera - flash don’t work and capacitor don’t charge
          by corrize
          Hello, I'm stuck in troubleshooting…
          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
          10-01-2022, 10:02 AM
        • Prolog
          RTX 3080 FE Identifying capacitor
          by Prolog
          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
          I hope these photos make it clear which component I am referring to:
          (yes, the soldering is a bit botched from removing the blown one, I know)
          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
          12-01-2024, 08:27 PM
        • quickname
          Cyberpower 1500AVR UPS repair
          by quickname
          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
          Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
          I decided to verify that the batteries were...
          11-12-2023, 09:57 AM
