Newbie question on recapping
  • KidD01
    • Sep 2010
    • 8
    • Indonesia
    A quick question regarding recapping on motherboards. Is recapping means changing all electrolytic caps on the board?
    Thanks in advance.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Newbie question on recapping
    Not necceassrily. Oftentimes you only have to replace the obviously failed and/or all the ones of junk brands. Sometimes there are good caps mixed in with the bad ones that don't need to be replaced.
    • mariushm
      • May 2011
      • 3799
      No. Usually the capacitors are grouped by functionality... a set of capacitors near the cpu handles the processor power, a group takes care of the memory power, others take care of pci express slot, others handle the chipset and auxiliary functions.
      The capacitors near the processor may go bad or go weaker sooner due to heat or simply the fact that they're "stressed" more throughout the computer's use. So for these, it's safer to replace the whole set, not just the ones that look bad, because you can't tell how much life the others have.
      The capacitors taking care of other functions may be just fine for longer time.
      • KidD01
        • Sep 2010
        • 8
        • Indonesia
        Thanks for the replies. I got 4 socket 478 motherboards which are problematic in stability. after careful inspection they may require recap. At first those boards use "non branded" PSUs which also got cap problem. It took me a week to figure out capacitor problem, the caps not bulging so at first I thought it's safe *face palm*
        Time to do some cap shopping now
        • mariushm
          • May 2011
          • 3799
          Just be careful you can't buy just any kind of capacitor that has the same uF value and voltage rating.
          On motherboards in particular, the replacement capacitors need to have low ESR and high ripple values, so if you don't know how to determine those do yourself a favor and show here the boards and maybe we can suggest where to buy and what to buy to be sure the replacements will work.
          • KidD01
            • Sep 2010
            • 8
            • Indonesia
            thanks, marisuhm. I found LXZ and KZH seller on my local area. No idea if it's the real thing or notthough. On the bad side the PSU I recapped can not start up. Will post with photo on new thread to ask advise on it. It's china made non branded type
            • proxneo
              Recapping Sony ICF-SW55 - verifying cap values
              by proxneo
              Dear reader
              I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
              At the moment, I have selected replacements based on the following list of values:
              3 x 470uF 10VDC
              3 x 4.7uF 35VDC
              4 x 47uF 50VDC
              8 x 22uF 6.3 VDC
              1 x 220uF 6.3VDC
              5 x 100uF 6.3VDC
              Which...
              06-21-2023, 12:38 AM
            • Use2bavolvo
              Bad Caps affect on time / clock functions
              by Use2bavolvo
              can someone please help elaborate if a bad cap will affect time / clock functions. My fancy coffee machine has a preset pour for espressos's all of the presets are way out of wack what use to be 25 seconds is now 12.
              I am about to replace the psu caps but need some guidance if a bad cap would slow down or speed up clock functions?
              02-13-2023, 06:59 PM
            • Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
              by Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
              03-15-2024, 09:37 AM
            • Green Probe
              Recapping a Denon AVR X6400h SMPS
              by Green Probe
              (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
              Disclaimer: I'm an amateur hobbyist and will get things wrong.
              Always use caution when working around mains power and high voltage capacitors!
              Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
              SYMPTOMS:
              -No display...
              07-18-2025, 03:36 PM
            • mtrento
              robomow rs serie power supply board PCG6005B not charging
              by mtrento
              i'm trying to repair my mowner's power supply unit which doesn't provide the 34VDC from the control electronic board. (PCG6005B)
              As i'm newbie in electronic repair ,i 'm seeking for advices.
              i can solder things and have some voltmeter
              here's a picture of the board .
              note : the input power is 34V DC and the output (white connector on the left) output 0V .
              when i turn on power , the status leds light up as normal (this board is measuring if the peripheral wire is cut , and can see when the robot is on it's base , all theses functions seems to work...
              03-26-2025, 04:18 AM
