Samsung 2s to black - semi resolved
  • Ken-f
    • Mar 2012
    Hi, this is my first time posting. I hope this is in the right area.
    I recently got a faulty samsung 2333swplus monitor that had the dreaded 2s to black issues.
    After reading a thread on here, I decided to test my luck and replace the capacitors. I replaced 7 of the 9 'normal' capacitors. Sorry, I'm not too sure of the terminology. Just the cylinder looking ones.
    Put it all back together, NOTHING! :'(. Same issue. So i continue reading online and someone suggested to lower the brightness. ... it worked!!
    So now I can use the monitor, at a lower brightness. I tried to raise it back to 100% and it still works, however, after about 15 mins. It goes back to black screen again. So I turn it off and on and it works for a while again.
    As the issue was not first related to the 7 capacitors I replaced. Would this likely be caused by the 2 remaining caps or something else?? It just so happens the 2 I didn't replace were the biggest and smallest ones on the board.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung 2s to black - semi resolved
    I have a Benq that exhibits the exact same behaviour. Since I had 2 identical monitors, I found out it was the ccfls or its wiring that were bad. I haven't taken it apart to see if it is the ccfls and/or its wiring.
    You can try replacing the smallest ones since the biggest one rarely, but not never, fails.
    More on the entire subject starting at posts #19 and #20 at
    https://www.badcaps.net/forum/showthread.php?t=10419
    --- begin sig file ---
    --- end sig file ---
    • Toasty
      • Jul 2007
      • 4171
      What caps did you use? Brand? Series?
      Can you post some pics the next time? Even the power board number would be a start.
      Toast
      veritas odium parit
      • Ken-f
        • Mar 2012
        I used nichicon capacitors.
        After further testing. I've been able to use it at 100% brightness for over an hour now. It just switched off. I checked to see if I could see anything with a torch and the picture is still there, but the backlight is off.
        When turning it off and on again, the picture worked so I lowered the brightness to 0%. Theres a soft buzzing now, and as I increase the brightness back to 100%, the buzzing fades. The moment it gets to 100% brightness, the buzzing is completely gone.
        Does that slim down what it is? I've already re-packed? the monitor so I don't know any numbers etc.
          09-07-2024, 05:50 AM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
