Need info on Rubycon YXC caps
  • berniedd
    • Mar 2007
    • 119
    I'm looking to use Rubycon caps for PSU and mobo repair. I got them from ebay, and they look genuine, good external appearance. They are 3300 uf, 10v caps and marked as YXC and (what I think is) a date code T9715. I've looked at the Rubycon website and I can't seem to find any info about this series.
    I'm also looking at a bunch of Nichicon KY series. Again, Nichicon website doesn't list them. Discontinued series perhaps?
    Your Comments?
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Need info on Rubycon YXC caps
    Those YXCs are 15 years old (a good reason not to buy them, unless you want to re-form them) and not very low impedance by modern standards (not suitable for use in a modern product, except possibly as a good quality GP part). KY is a United Chemicon series, fairly modern and decent. But that they are listed, apparently, as made by Nichicon suggests they may not be genuine.
    PeteS in CA
    • nick3092
      Mid/late 80's Nichicon Yellow Caps
      by nick3092
      I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
      08-28-2022, 03:56 PM
      by momaka
      03-12-2025, 03:42 PM
      by momaka
      03-15-2023, 10:17 PM
      no-name Radeon 9600 XT recap and cooler
      by momaka
      I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
      This one was actually suggested to me by ChaosLegionnaire....
      11-06-2020, 07:54 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
