GeForce 6600 Blown Capacitors
  • dime_f
    • Jan 2012
    • 3
    I have GF 6600 and just figured out that 3 of my capacitors are very very damaged. (attachment)
    The Capacitor parameters are: FZ5C 1500 6.3V. does anybody know replacement for this? What does 1500 means? 1500 uF ?
    Regards
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Re: GeForce 6600 Blown Capacitors
    Sacon FZ, known crap. Replace all with Rubycon MBZ at the least.
    Yes, your caps are 1500uF 6.3v. You'll also need two 330uF/16V caps for those other two Sacons. Replace every cap with "FZ" in it.
    • dime_f
      • Jan 2012
      • 3
      Thanks for the info.. I'll replace those 5 caps.... It's funny how the card still works without nvidia drivers installed.. When I'll enable nvidia drivers everything go in hell...
      Happy New Year!!! cheers
      • Hemingray
        KABOOM!
        • Jul 2010
        • 143
        Be sure you use low ESR capacitors, such as Rubycon MBZ. General purpose caps (like the ones Radioshack sells) will not work.
        • mariushm
          • May 2011
          • 3799
          Panasonic FM/FR , Rubycon MBZ/ZL*, Nichicon HM/HN/HZ, UCC KZE ... all will work fine.
          The board worked fine with those Sacon going out of spec for months probably, so there's some room, no need to search for super ultra low esr like those MBZ capacitors.
          • onegoodpcguy
            • Sep 2011
            • 15
            why do a half-ass repair job?
            if your ordering parts anyways the price differance is in the cents...
            • mariushm
              • May 2011
              • 3799
              It's not a half assed job. The specifications of the capacitor series above are all within a few percent of those MBZ series capacitors.
              The MBZ series was discontinued in 2010 and according to the datasheet, the last large orders for this series were accepted in 2009.
              So, no matter where you'd order such capacitors, they're at least 2 years old and you have no guarantee they were stored in reasonable conditions, unless you happen to find them at some well known distributor.
              Further, precisely because people like you recommend them and praise them, there's a lot of fakes out there so if the person tries to get them off eBay, it's quite possible he's gonna get fake stuff.
              Here's for example a comparison between MBZ and ZLG:
              https://cdn.badcaps-static.com/pdfs/...3bb75aa682.pdf
              1500uF 6.3v ZLG : 10x20 2180mA 0.014 ohm
              1500uF 6.3v MBZ : 10x12.5 1540mA 0.026 ohm
              1500uF 6.3c ZLH : 8x20 1500mA 0.029 ohm
              and there are other series... so you have a slightly taller capacitors with better specs... or thinner and almost identical specs... and do you really think 2 year old capacitors will actually have those datasheet specs?
              And even more importantly, do you think the circuit is so finely tuned, it would care about 0.026 or 0.014 when the Sacon caps had 0.020 ohm or something like that in the datasheet and they were crap.
              ZL* capacitors are available and they're cheap, no need to keep using old stock capacitors: http://uk.farnell.com/jsp/search/bro...57+100329+2031
              Same story with the other series.
              http://www.rubycon.co.jp/en/catalog/capacitors.html
              http://uk.farnell.com/jsp/search/bro...B100329%2B2031
              • onegoodpcguy
                • Sep 2011
                • 15
                you made alot of good points.
                i dont know these things, your first post sounded like half-ass.
                but your reasoning is solid as it gets...
                caps are so complicated, im still learning.
                thanks for the explination on all that, i like panasonic caps. i get them from digikey.com they seam to be really good i select caps based off the hours @ 105c i like the 5000-10000 hour models. so i most likely wouldnt have bought the ruby's but i know ruby and feel there good. infact i bought some 3300uf 6.3's MBZ off ebay a few months ago they've fixed quite a few motherboards.
                i didnt realize they were "OLD"...
                  NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                  The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                  10-02-2024, 08:52 AM
                  NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                  The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                  10-02-2024, 07:51 AM
                  NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                  The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                  10-01-2024, 01:54 PM
                • jossbnr34
                  Msi Geforce RTX 3060 Ti Twin Fan 8G (Missing Capacitors)
                  by jossbnr34
                  Hi, recently acquired a second-hand MSI Geforce RTX 3060 Ti Twin Fan 8G LHR graphics card. After spending two days trying everything and going crazy because my PC didn't detect it, and the fans weren't spinning, I couldn't figure out where the problem was. Yesterday, I found that some capacitors were missing, and some were broken. I imagine it might have been due to a fall or something like that. I'm trying to find a diagram of my card to see what type of capacitors it uses and their voltage to attempt a repair if possible. I'm new to this, but I have done some simpler soldering repairs on video...
                  09-24-2024, 09:40 PM
                  Thermal pad thickness for various laptop GPU / Graphics Cards
                  ASUS Dual RTX 2070 OC 8GB
                  ASUS ROG STRIX RTX 3080 OC
                  ASUS ROG STRIX RTX 3090
                  ASUS TUF Gaming RTX 3080 OC Edition
                  ASUS TUF GTX 1660 S-O6G GAMING
                  EVGA RTX 3060 Ti XC GAMING 8GB
                  EVGA RTX 3060 XC GAMING 12GB GDDR6
                  EVGA RTX 3080 FTW3 ULTRA GAMING
                  EVGA RTX 3080 TI FTW3 ULTRA GAMING
                  EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                  Gainward RTX 2080 Phoenix GS Specs
                  Gainward RTX 3070 Phoenix 8GB
                  Gainward RTX 3080 Ti Phoenix
                  GIGABYTE AORUS RTX 3080 MASTER 10G
                  02-09-2024, 08:08 AM
