any one else notice how many bp6/vp6 on ebay show bad caps?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    even when seller states the board is in perfect working order?
    seen quite a few with bulging caps in the pics.that is when the pics are any good.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Funny you mention that..... That's the first thing I look at when I see a VP6 on ebay. I see A LOT of them where the seller says the board works perfectly, but looking at thier pics, the caps are bloated and have vented... If the bidding was low on the item, I'll watch them and snipe them... Then recap and resell them. I haven't gone BP6 hunting in a while... I could use a BP6 though, I have a matching pair of 533 CPU's, and no board for them.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      just did a bp6 for a customer.
      had the teapo caps but none bulging.
      board had video artifacts and would reboot loop.
      found 1.5v p-p of trash on vcore.
      yep new caps fixed it.
      so if i look for these boards i just assume they need recapping and buy cheap.
        by momaka
        03-15-2023, 10:17 PM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
        Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
        by momaka
        This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
        Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
        Macron Power Technology Co. LTD.
        Let’s look at the PSU itself.
        The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
        06-02-2021, 10:05 PM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
