Rubycon MHB ??
  • SIDMX
    • Nov 2010
    • 165
    • Mexico
    Rubycon MHB ??
    Does anyone knows the specs for this series ?
    The caps (i have two) are 10x12mm couldn't find any specs in web. I suspect, they maybe already discontinued, also they look like if they were stored for several years so... it is safe to use them?... or is it better to trash'em?
  • kc8adu
    rubycon mh series 1000@16 10x12mm.old or fake?
    by kc8adu
    All the mh mh5 mh7 ect are subminiatures with no 1000uf@16v.
    Ancient or fake?
    Found in the power supply of my logical devices chipmaster 6000
    Compare to a mbz i had handy...
    02-28-2022, 03:12 PM
  • TomGJ
    Genelec 8020C Bad capacitor
    by TomGJ
    Hi All, So I have two Genelec 8020Cs that are about 10 years old, one of them stopped switching on. I took it apart, fuse was blown, and I've traced the short to one of the two large capacitors on the circuit board.
    Now from looking at the Capacitors, they seem to be from Samwha's SD Series with the following specs: 3300uf, 35v, 85C, 25 x 16 mm Radial.
    The problem is, I can't find any capacitor from Samwha's SD Datasheet that matches these specs. The closest is 3300uf, 35v, 85c but 31.5 x 16mm, with a max ripple current of 2.5A. I'm guessing the 25mm is custom made for...
    11-02-2024, 07:45 AM
  • rwkish
    Discontinued Capacitor looking for Replacement
    by rwkish
    Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
    08-18-2024, 06:54 PM
  • P4C800
    ASUS P5A and P2B-S recapping. Searching old datasheets.
    by P4C800
    I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
    There are three mainboards:
    - ASUS P5A rev 1.04
    - ASUS P2B-S rev 1.03 "Rubycon"
    - ASUS P2B-S rev 1.03 "Chemi-Con"
    If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
    They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
    P5A
    10-09-2023, 05:55 AM
  • badcap111
    How to read inductor specs?
    by badcap111
    I have a broken samsung galaxy s10 with missing inductor. I want to replace the missing inductor and I have found some vendors. But I don't understand how to read the specifications of the inductor. The specs are:
    INDUCTOR-SMD;470NH,20%,2520,T0.8,0.029OH
    I understand that the inductor is 470 nH with 20% margin, and the size is 2520 or 1008 (imperial measure), but what do T0.8,0.0290OH mean? I can't find any explanation on the web.
    09-12-2023, 01:25 PM
