Thank you
  • dharris
    • Jul 2011
    Thank you
    Just a quick THANKS to this site for saving my fathers computer. Being retired and on a fixed income, he did not want to have to purcahse a new computer. After some searching online for the solution to his BSOD I came upon this site. I ordered a set of 1800mfd@6.3v and replaced them on the MB. I was now finally able to reinstall his OS and get things running again. Again, THANK YOU. I don't repair MB's often but I now know what to look for when I do have interesting problems.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Thank you
    You're very welcome!! Thanks for your business!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • AJ2021
      Sharp LC80UH30U Vertical Band
      by AJ2021
      I just moved to a new apartment and now I got a vertical band on my tv. The band is changing colors all the time. Is there a fix for this? If someone has had the same problem and fixed it I would really appreciate the help as I am retired and on a fixed income and cannot afford a new tv.
      I can change any boards and bad caps but I'm not good with a volt meter.
      Thank you very much for any assistance....
      01-30-2022, 10:57 AM
    • insomniacno1
      Thinkpad L540, won't turn on unless I switch ram
      by insomniacno1
      This is a very weird problem and super annoying, so if someone who has experience with this, can explain why this is happening, then I will be grateful😁
      This happen usually when the laptop has been moved. from one room to another OFF charger for some hours, but has also happened when laptop has been shut down and left ON charger over night, and not moved :
      I turn on the laptop normally by pressing the power button briefly, then power comes on and Power LED and Fn LED turn ON/OFF constantly (no post and no beep codes)
      If I(and this is my only option at this point),...
      09-29-2025, 05:58 AM
    • DrDos
      Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
      by DrDos
      Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
      08-08-2025, 03:16 AM
    • DrewPhillips
      Capacitor Diarrhea - Nichicon PL Series
      by DrewPhillips
      Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
      The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
      03-02-2025, 10:18 PM
    • Babbar
      1980s Holz Her 2420 belt sander - Only works when speed control at maximum
      by Babbar
      My fathers belt sander from the 80s which i very much would like to continue using has an issue with the speed control. The machine works fine on maximum speed but will not turn or give any sign of life when on any other setting. The speed control is a dial going from 1-6 although implemented as a potentiometer without distinct steps. I took the machine apart and measured each component individually, all components and measurements have been captioned in the attached pictures. The Triac did not get identified correctly using my cheapo component tester, i don't know if this is user error, if the...
      11-13-2024, 01:54 AM
