Apple iMac G5 and iMac G5 Isight 20" Capacitors Location
Re: Apple iMac G5 and iMac G5 Isight 20" Capacitors Location
On the first picture, more correctly, that's the iMac G5 with ALS ( Ambient Light Sensor ).
The ALS plug on the board is at (under) the upper right corner of the cap designations.
The "run of the mill" iMac G5 does not have:
3 - 120/16
2 - 1500/4
and only has
20 - 1800/6.3
Thanks for the pics!
Toastveritas odium parit
Originally posted by badassbarberi have a imac g5 20 inch als. when i start up the computer, everything starts up fine but the picture is all fuzzy and blury. all three leds on motherboard are solid green and the capacitors all look fine. i have reset the PRAM but no luck....any ideas what it could be?????jamesLast edited by retiredcaps; 06-10-2011, 03:10 PM.--- begin sig file ---
--- end sig file ---
