Cap identification help needed.
  • omega329
    Story, one of my 2 Samsung syncmaster 906Bws started not working. I would turn it on, picture would display for 1 second, then go out, so I stuck a flash light to it and I could see the image, did some research and apparently the psu/inverter board has bad caps. Opened it up, I see 3x caps right next to each other that are slightly bulging at the top, they are not leaking or anything, but they are not indented like the others in a different location. I need some help identifying the caps, as I have no cap replacement experience. A LINK to a place e-tailor would be appreciated, or maybe even something buy able to radio shack.
    The are black with 1 side in white (the ground), they have the words
    (JH) probably logo
    CD284
    +105C
    7143H
    25V
    470uf
    Any help is appreciated
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Cap identification help needed.
    See
    https://www.badcaps.net/forum/showpo...&postcount=459
    --- begin sig file ---
    --- end sig file ---
    • lisahamp871
      Help Needed for PSU Board Identification
      by lisahamp871
      My almost 15 years old desktop PC decided it was about time not to power on anymore. I replaced the PSU with a spare one I had and it went back on so I guess it was it. Now I'd like to try to take a look at the old one that went bust but I'm having trouble in identifieing it. I've taken some pictures of the board but haven't been able to find the schematics or almost anything online, expect for the LC500H-12 itself, the inside board seems to not showup anything.
      Any assistance in identifying the board or pointing me toward the right schematics would be greatly...
      08-20-2025, 08:36 AM
    • Ado02
      DELL 15 3505 LA-K001P PD1 - Identification Needed
      by Ado02
      Can anyone help me identify the PD1 component on LA-K001P motherboard?...
      05-06-2022, 09:21 AM
    • Shulgin
      Acer predator XB241YU Component identification
      by Shulgin
      I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
      After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
      In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
      I...
      05-11-2024, 11:06 AM
    • DeXXter
      Replacing SOC SRK08 clean me needed?
      by DeXXter
      Hello, so I replaced a soc SRK08 (i3-1115G4) on a hp 14-dq because the 1.8v power supply was shorted and the pch was gone and I installed a SRK05 (i5-1135G7) that I had at hand. And I was wondering if a clean me region is needed after replacing the chip, I usually do this on laptops with separated pch, but with a soc (cpu and pch together) I have no idea. Normally I wouldn't ask this, but I have only the motherboard, no screen nor the adapter, and after I fix this I have to send it to another region so if someone knows about this, some help would be apreciated.
      Note: After doing all...
      11-19-2025, 03:16 AM
    • mohammed mohan
      BIOS file needed HP PROBOOK 445 G6 DA0X9KMB8E0 REV E
      by mohammed mohan
      BIOS file needed
      HP PROBOOK 445 G6
      DA0X9KMB8E0 REV E
      S/N 5CD92213CN
      No backup available
      10-29-2025, 05:25 AM
