Graphics performance worse after recapping?
  • krokett
    • Jan 2006
    • 5
    I had been doing some research into recapping my old epox 8rda+.
    It did show the obvious symptoms of bad GSC capacitors.
    So, I did order enough to replace all GSC caps, leaving the good ones (Sanyo an d others) on the board.
    It wasn't too easy to perform the repair, it sure did take me some time. Eventually, I got there.
    Mounted the motherboard, and restarted the machine. The machine booted fine and works fine. Although, when I decided to play COD there seemed to be an issue; gameplay was slightly jerky. Movement of characters wasn't as smooth as it was before the repair. It's playable, but I can tell something is wrong.
    I did notice during the procedure that I removed a cap (TEAPO 1500 6.3v) between the AGP and 1st PCI slot, which I shouldn't have removed. I soldered it back.
    Well, even though I am glad the result was way better than for some other people who had bad luck of completely toasting their mo/bo, it still bothers me. You know, that little thing that keeps nagging at you constantly.
    So, do you guys think a badly soldered cap or one damaged in the process could be the source of my problems?
    Thanks for the input.
  • davmax
    • Dec 2005
    • 899
    Re: Graphics performance worse after recapping?
    Suggest you replace that Teapo. It may have been toasted by the heat of removing and replacing. Take care the motherboard vias may not suffer too removals.
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      you did not mention what new caps you used. replace the teapo definitely. what else is in the region of AGP? (davmax was faster than me hehehe)
      • krokett
        • Jan 2006
        • 5
        The caps were replaced with Nichicon PW series caps.
        5 x 6.3V 1500uF
        8 x 6.3V 1000uF
        4 x 10V 2200uF
        So, I take it from your info that caps and soldering heat don't do too well?
        Geez, when I was soldering some new ones the top of some of them felt lukewarm to the touch, not that I did it on purpose, but some were touch to hold in place, since small size caps are hard to come by.
        Are those toast too?
        • linuxguru
          • Apr 2005
          • 1564
          They can withstand normal soldering temperatures for a short while - say a minute - without problems. Only if you heat and reheat them repeatedly, for instance in a botched soldering job, will you get a cap with a greatly reduced lifespan. The smaller the cap, the more vulnerable it is to excess heat.
          • davmax
            • Dec 2005
            • 899
            The Teapo may be in doubt in any case. What caps are you using as replacements?
            Nvidia 8500GT 256Mb
            33 way card reader
            Windows XP Pro SP3
            • davmax
              • Dec 2005
              • 899
              Bit worried about the one minute to soler time. That seems too long. Have tried to pickup a figure but all reference are to surface mount caps where it is only 10seconds at 260C. Somebody may post a reference.
              Nvidia 8500GT 256Mb
              33 way card reader
              Windows XP Pro SP3
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                well, Chemicon say 10 seconds at 260 or 3 at 350. This is one of the reasons why it is not good to remove caps and then use them again. The removal time is much longer than the soldering time. soldering should only take a few seconds just to close the hole so the new caps get subjected to minimal heat. the real problem is during removal where it is possible to heat the area around the via for too long periods thereby damaging either a trace or the via itself. In hot and fast is the preferred method.
                anyway, the OP got a post and so his soldering cant be that bad so before we jump to conclusions best to replace the teapo and see how that goes.
                • Rainbow
                  • Aug 2005
                  • 1371
                  I think that it's software problem.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    clear the cmos first.
                    just handeling the board outside the case can corrupt it.and change all crap brands.a teapo is a possible crapcap but not as common as a gsc or ost.
                    • krokett
                      • Jan 2006
                      • 5
                      5 x 6.3V 1500uF
                      8 x 6.3V 1000uF
                      4 x 10V 2200uF
                      By the looks of it, I will probably order me some new caps, and redo the procedure. Wanna bet I will toast it this time?
                      But first I will follow the suggestions of some people about the CMOS and software.
                      I wished I could just buy one, but most businesses charge you a flat fee for small shipments, so I might as well get the whole thing.
                      The funny thing is that 2 months ago, after having my PC dismantled for 5 months or so decided to put it back together and my Barton 2500+ couldn't run at the previous o/clocked speed of 2200 MHz. Had to throttle it back to 2100 NHz. Now, after the recap procedure I can run it at the previous o/clocked speed. At least that worked.
                      I am still looking for which brand to get now, and am considering 3 sources to get them from; badcaps.net, digikey.com, and mouser.com. Although mouser.com is last on my list since I specifically asked them to wait until all backordered items were delivered to ship my order, but they didn't.
                      I am sending a request for badcaps.net first.
                        ASUS VivoBook Performance Laptop Notebook Pro Specification for Upgrade or Repair
                        This specification for the ASUS VivoBook Performance Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Performance Laptop boardview and Performance Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 07:00 AM
                        Fujitsu LIFEBOOK P728 Hybrid (2-in-1) P Specification for Upgrade or Repair
                        This specification for the Fujitsu LIFEBOOK P728 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P728 boardview and P728 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu...
                        09-06-2024, 06:17 AM
                        Acer Switch SW713-51GNP-80Y3 Hybrid (2-in-1) 7 Black Edition Specification for Upgrade or Repair
                        This specification for the Acer Switch SW713-51GNP-80Y3 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SW713-51GNP-80Y3 boardview and SW713-51GNP-80Y3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 07:58 AM
                        Microsoft Surface Book Surface Book with Performance Base Hybrid (2-in-1) Specification for Upgrade or Repair
                        This specification for the Microsoft Surface Book Surface Book with Performance Base Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book with Performance Base boardview and Surface Book with Performance Base schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-06-2024, 08:20 AM
                        Lenovo Yoga 730 Hybrid (2-in-1) 700 Specification for Upgrade or Repair
                        This specification for the Lenovo Yoga 730 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 730 boardview and 730 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo Yoga 730...
                        09-06-2024, 07:36 AM
