asus a8r32-mvp deluxe,one bad cap?
  • 4thman
    • Oct 2008
    I received this mobo second hand,it came from a working system with no issues.Upon closer inspection it has one slightly swollen cap by the blue pci-e slot,it's located at the end on the pci-e slot towards the vid card clip.The top of the cap is KZG,6.3v,820uf.This mobo has many of these caps,ugh.What is the purpose of this cap?How long can it last?And will all the caps need to be replaced?Thanks.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: asus a8r32-mvp deluxe,one bad cap?
    United Chemi-con makes the KZG cap. Normally, United Chemi-con makes good quality caps, but the KZG series are problematic as per
    https://www.badcaps.net/forum/showthread.php?t=2280
    Members here will recommend that you replace the KZGs.
    --- begin sig file ---
    --- end sig file ---
    • 4thman
      • Oct 2008
      Damn,thanks.Didn't figure this problem was still ongoing on "newer" mobo's.Older p3 and p4 mobo's and athlons I was aware of.Haven't heard of any probs with this particular mobo and yet I appear to have the only one that does,lol.Well I'm going to do a quick build with it using spare parts and get it working,then I guess I'll take it apart and try to repair it,a friend of mine has replaced caps in the past,I'll get him to take a shot at it.Thanks.
      P.S -which brand/type cap should I use to replace them?
      • retiredcaps
        • Apr 2010
        • 9271
        PCBONEZ talks about choosing the right caps ...
        https://www.badcaps.net/forum/showpo...47&postcount=3
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5045
          • US
          does it work? meh dosn't matter. Just because its one slightly bloated cap dosen't mean the rest of those KGZ's are good. KZG's have a tendancy to go bad without bloating
