Starting from scratch with Mitsubishi DLP problem
  • Bama
    • Jan 2011
    I have a Mitsu WD65734 DLP TV that is giving me a steady red status light on front panel. Everything I can find online points to either a cap problem on PS board or a lamp issue. Can anyone enlighten me as to which is more likely?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5095
    • New Zealand
    Re: Starting from scratch with Mitsubishi DLP problem
    I have no idea, but if you open it up and look at the PSU you should be able to spot any failed capacitors.
    Uploading some photos here would be useful, and should help you get help
    -David VanHorn
    • Bama
      • Jan 2011
      So I learned how to get error codes - came back an error code 48 which evidently indicates a problem with the PWB Main board. Now the question is whether or not the PWB Main board is one that has bad capacitors, or I just need to buy a whole new board. Any ideas?
      • TheLaw
        • Jan 2011
        • 477
        Well...I'm not sure where you would just get a OEM board. Maybe they make replacements? Well, you'd have to do a visual inspection. If any of the caps are bulging, leaking, or just look strange, it could be the reason. It depends on how many have gone bad I guess. And if anything else looks messed up...
        • Agent24
          I see dead caps
          • Oct 2007
          • 5095
          • New Zealand
          Don't forget that in a faulty system any error codes may in fact be wrong because of the fact that there is a fault somewhere.
          The fastest way to know if there are bad capacitors is to open the thing and look at them.
          If anything looks suspicious, upload photos here, we can see what's what...
          -David VanHorn
          • Bama
            • Jan 2011
            Thanks for the feedback - I'm going to open the set up tonight and begin inspecting things. Probably start with primary power supply. If it's bad, who knows what kind of error code would appear.
            • ravi_1617
              Lenovo B540 ,Starting Problem
              by ravi_1617
              Hello !
              Model Lenovo B540
              Board Details 09244-1
              LA14 DIS MB
              48.4DMO4.01.1
              This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
              when connected CMOS dont start.
              3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
              One more thing i want to mention ( by mistake i started at...
              10-14-2025, 02:08 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
              HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
              This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
              09-06-2024, 08:30 AM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
